Trying to pull down overhaed console - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-15-2007, 11:44 AM   #1 (permalink)
Toytruckmike's Avatar
Gameroom cash: $116920
View Toytruckmike's Photo Gallery
I searched and what little I found said to just unscrew the 1 screw and pull it down.
Since I am famous for breaking things, I an nervous about how hard I should be pulling.
The headliner seems to be pulling down with it.
Do I move the console before pulling, or just pull straight down?
Thanks,
Michael S.
Toytruckmike is offline   Reply With Quote
Old 09-15-2007, 01:09 PM   #2 (permalink)
rdsaustintx's Avatar
View rdsaustintx's Photo Gallery
Did this yesterday.
There are FIVE points supporting the console.
TWO snap-ins at the front.
ONE phillips screw in the sunglass holder.
TWO rear-facing hooks at the back, hooking over the edge of the headliner.
You ain't gonna believe how easy this is.
1. Remove the phillips screw.
2. Pull down on the front of the console until it snaps out.
3. Remove the console with a slight forward motion to clear the hooks.
Toughest part is holding onto the thing while removing the electrical connectors (2).
rdsaustintx is offline   Reply With Quote
Old 09-15-2007, 01:25 PM   #3 (permalink)
Janster's Avatar
View Janster's Photo Gallery
Just pulled mine down yesterday....
Remove screw and gently pull down on the front of the console. You can pull down slightly on each side at a time and rotate back-n-forth. It'll pop down.
http://www.lieblweb.com/
Janster is offline   Reply With Quote
Console Vault *GROUP BUY* nomad 2nd Generation (2005+) 199 07-23-2008 06:00 PM
Center Console paint repair help whitenoize 5th & 6th Generation (2002-2006 & 2007-2011) 7 03-08-2007 09:47 AM
Solution: Rattle/Squeak in center console of 07 Camry ToyotaCarFan 5th & 6th Generation (2002-2006 & 2007-2011) 6 11-16-2006 01:41 PM
Gen 5.5 Overhead Console (Map light Mod) need some help drew_gen5_5 5th & 6th Generation (2002-2006 & 2007-2011) 2 10-30-2006 02:02 PM
How do you get the center console out? (92 Camry) cmjohnson 3rd & 4th Generation (1992–1996 & 1997–2001) 6 12-01-2003 01:22 AM
