Originally Posted by DirtyTaco
Hey Toku, how's your ride compared to when it was stock? I'm considering a lift but don't won't suffer a rough ride. Thanks, and sorry for the hi-jacking.
It rides a little stiffer. But that Actually works better considering the increase in height.
The only issue I have; is that the shocks are too short. The down travel is limited. It's O.K. if you drive slow over bumps. But you will feel the jarring thud of the shocks when they max out, if you decide to go over bumps fast.
But if you are on a budget? (And you don't plan to do high speed desert runs). This is still a great; and affordable lift set up.
