air bag sensor light on - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 09-16-2007, 02:18 PM   #1 (permalink)
View jfdekruyter's Photo Gallery
I have a 2005 Tacoma and my air bag senor is on in the dash. What are some causes to that?
jfdekruyter is offline   Reply With Quote
Old 09-16-2007, 02:26 PM   #2 (permalink)
I hate hippies.
tacogrande's Avatar
View tacogrande's Photo Gallery
unplugged connector is the most likely cause. Look for the bright yellow wires, those are for the airbags. Check the ones under the seats too.
tacogrande is offline   Reply With Quote
Old 09-16-2007, 02:26 PM   #3 (permalink)
Banned
BillBrasky's Avatar
iTrader Score: 12 reviews
View BillBrasky's Photo Gallery
check the weight senson connections under your seats.
BillBrasky is offline   Reply With Quote
Old 09-16-2007, 02:27 PM   #4 (permalink)
Banned
BillBrasky's Avatar
yeah.
Old 09-16-2007, 02:33 PM   #5 (permalink)
View fit24hrs's Photo Gallery
Let's hope it's that simple. Same thing just happened to me. There was an open recall on my truck for some sort of passenger cabele (recall #501 or something) but that didn't fix it. Dealer said I needed to change a clock spring cable or something. $470!!!!!!
fit24hrs is offline   Reply With Quote
Old 09-16-2007, 03:20 PM   #6 (permalink)
I hate hippies.
tacogrande's Avatar
Clock spring cable? You shouldn't have to replace that until your muffler bearings go out. Weird man.
Old 09-16-2007, 04:01 PM   #7 (permalink)
'Coma Nut
ForTech's Avatar
View ForTech's Photo Gallery
I replaced the clock spring cable, known as a Spiral Cable in my '98 Tacoma. The local dealer wanted $500 alone for the Cable, I got it from Toyota of Dallas for ~$180 or so shipped. Very easy to replace and shouldn't take more than an hour your first time. Just follow the FSM and you'll be fine should you decide to switch it out yourself.
ALSO - if your clock spring is damaged, your cruise control and horn usually doesn't work either.
2005 Tacoma TRD Off Road 4x4 Access Cab
ForTech is offline   Reply With Quote
Old 09-16-2007, 04:07 PM   #8 (permalink)
nooB nooB noo
View Larzzzz's Photo Gallery
Aren't they lubed for life?
'06 DCLB Indigo,Scangauge II, Redline tuning hood struts, map light mod, trailer plug mod, LED bed lights Thule X-sporter racks. Aux. back up lights.
Larzzzz is offline   Reply With Quote
Old 09-16-2007, 04:17 PM   #9 (permalink)
View rentz's Photo Gallery
my new 08 has an airbag light thats always on in the center console area, i assumed that was normal, or is this something different?
rentz is offline   Reply With Quote
Old 09-16-2007, 04:23 PM   #10 (permalink)
forget about "tsb's"
6shooter's Avatar
Gameroom cash: $110100
View 6shooter's Photo Gallery
keep in mind that while that light is on, the airbags will not go off if you get into an accident
6shooter is offline   Reply With Quote
Old 11-23-2007, 01:47 PM   #11 (permalink)
View jkrantz's Photo Gallery
I have 1 98 Avalon. First the cruise, then the airbag and horn stopped working. Replacement of the spiral cable (Toyota of Dallas) fixed all 3. Was an easy replacement!
jkrantz is offline   Reply With Quote
Old 11-23-2007, 02:30 PM   #12 (permalink)
C5 Meter Minder
hoofhearted's Avatar
View hoofhearted's Photo Gallery
What cab?
Did you turn the passenger side off??
You gotta be tough to fly the heavies!
hoofhearted is offline   Reply With Quote
Old 11-23-2007, 07:11 PM   #13 (permalink)
Originally Posted by hoofhearted View Post
What cab?
No
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
AIR BAG light on CamBOT 3rd & 4th Generation (1992–1996 & 1997–2001) 8 08-28-2007 02:23 AM
Turbo Charger Lwrdtoyota 89-95 Toyota Pickup/Hilux 92 07-26-2007 06:41 PM
Wow, I need help! please! Setheroo 89-95 Toyota Pickup/Hilux 7 06-05-2007 06:44 AM
978 Corolla Air Bag Light On - Why? azcorolla Archived Corolla threads 3 12-02-2005 04:52 PM
