PA15-TOY Installation Guide - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
#1 Old 04-08-2008, 01:27 AM
Lovin' my Taco!
Quoted: 0 Post(s)
(Thread Starter)
Hey all-
I got my USA SPEC PA15-TOY iPod adapter today for my '06 Taco & put together an installation guide with step-by-step pictures. This is an easy project that pretty much anyone can do. There are several other good installation guides for the PA11 & PA12 already. The installation isn't really any different...except mine says "PA15" on it.
So far I've only tried the PA15 with a new Nano running 1.0.3 firmware, but it's great so far.
Here's my installation guide: http://www.acceleroto.com/pa15toy/
Hope this helps!
-Groucho
Groucho is offline
#2 Old 04-08-2008, 01:31 AM
socalman22's Avatar
Quoted: 0 Post(s)
Good install!
Black Sand Pearl 2006 Dbl Cab LB,
socalman22 is offline
#3 Old 04-08-2008, 02:32 PM
Forumatic Immunity!
docindahouze's Avatar
Quoted: 0 Post(s)
iTrader Score: 9 reviews
can you still change music from the ipod or do you have to do it from the stereo? and also, does it charge also?
05 Tacoma DC LB TRD Sport Super White.
"I thought I'd get your theories, mock them, then embrace my own. The usual."-House.
docindahouze is offline
#4 Old 04-08-2008, 05:01 PM
I Like 'Ze Best
Rhino8541's Avatar
Quoted: 0 Post(s)
What is the difference between this and the pa-12toy?
Rhino8541 is offline
#5 Old 04-08-2008, 06:01 PM
i call it the octagon
chilidogrc's Avatar
Quoted: 0 Post(s)
will it work for the stock single disk HU?
the SPNKr
chilidogrc is offline
#6 Old 04-08-2008, 08:48 PM
Quoted: 0 Post(s)
can you add Xm to this as well as an Ipod?
2008 Tacoma DC 4x4 LB TRD Sport
1969 VW Baja Bug
Money Pit
Minor Mods
davidv2007 is offline
#7 Old 04-08-2008, 09:56 PM
Lovin' my Taco!
Quoted: 0 Post(s)
(Thread Starter)
It does charge the iPod. When you switch to another stereo mode (CD, FM, etc), it pauses the iPod & continues to charge it. You can control the iPod from the stereo controls including the steering wheel buttons. It recognizes playlists called "TOYOTA1" through "TOYOTA6" and tells the head unit they are "Disk 1" through "Disk 6." The Disk 7 setting plays all songs on the iPod...Disk 8 does the same, but in "Direct Mode" where you have to control what's playing through the iPod itself. Disk 9 is the AUX input (if you enable it).
For my 6-disk stock stereo, I don't think there is any difference from the PA12. I think the big new capability with the PA15 was support for "NAV radios through the SAT port" (quote from the USA SPEC site). It looks like it will NOT work with the new radios that will play an MP3 CD. I'm not an expert on it though...I'd check the USA SPEC site to find your make/model/year.
The way I read their site, it should work as long as that HU has a "TEXT" button.
I'm going to do this using it's aux input. It's just a stereo RCA connection, so pretty much anything that has a line out can be connected to it. If you wanted, you could add a 1/8" stereo jack to your dash. My plan is to wire my XM line output to the PA15's aux input. I haven't done that yet though. They say all you have to do is select "Disk 9" and it'll listen to the aux input.
I drove to work & back today with it (about 2 hours total) and it seems to work well. The volume is good & the sound quality is WAY better than an FM transmitter. I hadn't really read through the manual completely about what head unit buttons do what for the iPod control, but moving between playlists & songs withing playlists works well.
Groucho is offline
#8 Old 04-22-2008, 07:58 PM
+++++ J Runner +++++
Jotaro's Avatar
Quoted: 0 Post(s)
WERD!
Jotaro is offline
#9 Old 04-22-2008, 08:00 PM
Jotaro's Avatar
Quoted: 0 Post(s)
One thing I'm trying to figure out is that, when the ipod's been drain out of its battery and then you try to charge it via your PA15-TOY, it just wont, is it just me or has anybody experienced the same thing?
Jotaro is offline
#10 Old 04-22-2008, 11:27 PM
Lovin' my Taco!
Quoted: 0 Post(s)
(Thread Starter)
I have my portable XM hooked up through the aux input on the PA15 & it works great. To listen to it, all you have to do is select Disk 9. The sound through the aux input is good, but I did adjust my XM's line output level to its "high" setting to make the volumes match up.
I might have found a "bug" in it though. I turned on my car stereo & selected the CD-In (PA15) without an iPod connected. It waited patiently for about a minute, then the stereo switched to CD mode. After that, I could not select the PA15 even with the iPod connected. After trying everything I could think of (connect/disconnect iPods, stereo power, car power, etc) the only way I found to make it work was to pull the stereo out & disconnect & reconnect the cable between the PA15 & the stock stereo. Since then, I haven't had any issues, but I haven't tried to duplicate it either.
After several weeks of use with a 2 hour round-trip commute to work each day and a 600 mile road trip, I'm extremely happy with the PA15. The sound is great, the text display works perfectly, and the steering wheel/head unit controls are well integrated. Love it.
(No, I do not work for USA SPEC.)
Groucho - '06 Tacoma TRD
Groucho is offline
#11 Old 04-22-2008, 11:32 PM
Lovin' my Taco!
Quoted: 0 Post(s)
(Thread Starter)
I haven't tried connecting my iPod when it's low on juice. I've found that since the PA15 continues to charge the iPod for some time after the car power is off, my iPod has remained fully charged since I got my PA15. Nice!
Groucho is offline
#12 Old 05-10-2008, 03:22 PM
SHIFT this
Jaime's Avatar
Quoted: 0 Post(s)
Does anyone know if the pa15 cables are long enough to be routed under the manual (if it makes a difference) shifter and reach the center console?
2007 Base 6spd 4x4 - CarDomain
Jaime is offline
#13 Old 05-10-2008, 05:35 PM
Quoted: 0 Post(s)
Thumbs up
yup, I have a manual and routed mine to the center console. Works good!
valentinorossi is offline
#14 Old 06-06-2008, 12:17 AM
Quoted: 0 Post(s)
Still use CDs?
So, I've read everything I can find and I know the PA15-TOY works with the in-dash CD changer. But, does it take over the CD changer or can I still listen to CDs? If so, how? I've got a 2007 Tacoma.
tapuleo is offline
#15 Old 06-06-2008, 01:13 AM
Lovin' my Taco!
Quoted: 0 Post(s)
(Thread Starter)
You can still use your in-dash changer just how you do now. When you hook up the PA-15, it gives you another option with the CD button: CD-I (CD Input?). Under CD-I (the PA-15), you'll have 8 disk options (6 playlists & 2 types of direct selection mode). If you use the aux input on the PA-15, you'll have yet another disk under CD-I. Disk 9 becomes your aux input.
Groucho is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
