How to reset airbag light - Toyota Nation Forum : Toyota Car and Truck Forums
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
#1 Old 12-10-2008, 12:45 PM
Quoted: 0 Post(s)
(Thread Starter)
I think I have an airbag light come on. Its a light that looks like someone sitting down with a round ball in their lap in the tachometer. I think it went on after I honked the horn this morning. Could be coincedence. If it comes back on I know I have a problem. How do I reset it? I have way too many miles for warranty service. Thanks
usadaytrader is offline
#2 Old 12-10-2008, 01:07 PM
forget about "tsb's"
6shooter's Avatar
Quoted: 0 Post(s)
i wouldn't mess around with the air bag system, if it's on thqt means there is a problem. i would get it checked out.
6shooter is offline
#3 Old 12-10-2008, 03:01 PM
ASE Master Tech
Quoted: 0 Post(s)
Without the proper scan tool you can't reset it.
WCTacoTech is offline
#4 Old 12-10-2008, 04:47 PM
Quoted: 0 Post(s)
There's the old fashioned way, and it's listed in the factory Toyota repair manual if the scan tool does not remove the light.
Perhaps you've heard of "playing the drums?" You connect a service wire to terminals AB and TC in the 'DIAGNOSTIC' port on the engine harness. You know, the one we used to use for OBDI.
You then alternately ground (just use a strut nut or something) AB and TC in 1 second intervals. The timing needs to be right. It should start blinking at you. Do it until it clears. It's difficult.
We MR2 guys have had to do this to clear our air bag lights for years. Any work done near the dash (like installing a stereo) would set it off. It's still the same for OBDII when the scan tool fails.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline
#5 Old 12-10-2008, 05:20 PM
Stupid is stupid does
lotust's Avatar
Quoted: 0 Post(s)
like 6shooter says. I would not mess with it. Do what you want though.
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline
#6 Old 12-10-2008, 05:32 PM
Quoted: 0 Post(s)
(Thread Starter)
Light went off by itself. Thanks guys.
#7 Old 12-11-2008, 11:59 AM
Quoted: 0 Post(s)
The code is still stored in history and there is still a problem. I would have it checked out. Like others have said its a problem you want checked out, don't ignore it. Also it came on for a reason so to say theres no problem is a lie.
'06 Tacoma Double Cab 4x4, Auto , TRD-Off Road, Silver. BHL mod and removed emblems
Fabtech 6" lift W/Dirtlogic coilovers, 3" front spacer, 3" bodylift, 20" ProComp 5936 W/35" Toyo OpenCounty M/T tires, Camburg UCA's, longer SS brake lines.
integlikewhoa is offline
#8 Old 12-11-2008, 12:15 PM
ASE certified technician
Quoted: 0 Post(s)
You cannot reset an airbag light without fixing the problem. The system is made to report a problem the second it sees a problem. The only way to fix it would be to take it somewhere and have it diagnosed and the part that has gone bad, fixed. If it happened when you honked the horn, then it could be the spiral cable, and the steering angle sensor. or it could be something totally unrelated. Could be anything from a airbag ecu to a yaw rate sensor. simply "clearing the code" wont make it go away unless the problem somehow fixed itself. Which....i have seen happen without explaination. i know this happened with you...but i posting this as general info.
ASE/ Certified Toyota Tech in Dallas Area
Cody the Mechanic is offline
#9 Old 12-12-2008, 09:54 PM
Quoted: 0 Post(s)
Read below.
DTC Normal Source Voltage Drop
(no code is output, but the SRS light will stay ON)
CIRCUIT DESCRIPTION
The SRS is equipped with a voltage–increase circuit (DC–DC converter) in the airbag sensor assembly in case the source voltage drops. When the battery voltage drops, the voltage–increase circuit (DC–DC converter) functions to increase the voltage of the SRS to normal voltage. The diagnosis system malfunction display for this circuit is different from other circuits that is when the SRS warning light remains lit up and the DTC is a normal code, source voltage drop is indicated. Malfunction in this circuit is not recorded in the airbag sensor assembly, and when the source voltage returns to normal, the SRS warning light automatically goes off.
There is no other malfunction that would clear itself.
Jason
1991 MR2 N/A (SW21)
#10 Old 03-25-2009, 10:34 AM
tr7driver's Avatar
Quoted: 1 Post(s)
I'm trying to find this port on a 01 highlander V6 4wd. It is not above the rear timing belt cover on the air intake where I've seen it on other Toyotas. Any idea where I could find it?
Thanks
2001 Highlander V6 Limited 4wd
2005 Mustang GT Convertible
2014 Ford Fusion Hybrid
1979 Triumph TR7
tr7driver is offline
#11 Old 03-25-2009, 12:15 PM
Georgia
Jeddak's Avatar
Quoted: 0 Post(s)
Thanks
OBDI ports are always on the lower left under the dash, near the steering column. I never heard of them being in the engine compartment.
Impeach Chief Rat Roberts now!
Jeddak is offline
#12 Old 11-23-2011, 04:02 PM
Quoted: 0 Post(s)
I'm trying to rest the air bag system for my 2005 Corolla. You mentioned "connect a service wire to terminals AB and TC in the 'DIAGNOSTIC' port on the engine harness. You know, the one we used to use for OBDI." I'm trying to locate this port under the hood without success. Can you point me in the right direction. Thanks.
pormoonman is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
User Tag List
Linear Mode Linear Mode
You may post new threads
You may post replies
