Slip Indicator and Check Engine light - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Wheel & Tire Center
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 03-27-2012, 03:42 PM   #16 (permalink)
Senior TN Member
Chalkie's Avatar
Gameroom cash: $242705
View Chalkie's Photo Gallery
I have an '06, so I do not have a slip indicator light, however, the CEL coming on means that a code has been set by the ECU. You need to get a readout to see what code(s) have been set to get a better idea of what might be happening in your instance.
You know you live in Colorado if you know where the real 'South Park' is.
Chalkie is offline   Reply With Quote Quick reply to this message
Old 03-27-2012, 06:02 PM   #17 (permalink)
Senior TN Member
RTFM's Avatar
Gameroom cash: $498062
View RTFM's Photo Gallery
According to your manual:
Slip indicator
The indicator comes on to indicate a malfunction in:
The VSC;
The TRAC;
The active traction control system (if equipped);
The AUTO LSD system;
The downhill assist control system (if equipped); or
The hill-start assist control system (if equipped).
Reading about some other Toyota vehicles indicates ABS sensors may have been disturbed. Seems likely based on the items above.
The 05 manual suggests Master Brake Cylinder might be at fault.
Get someone to check the CEL code, and go from there.
06 DC LB, 4x4, Speedway , TRD Sport w/ Tow, JBL 6CD w/ Grom to IPod, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Hood Struts, Scangauge, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Toyo Open Country AT tires
RTFM is offline   Reply With Quote Quick reply to this message
Old 03-27-2012, 06:57 PM   #18 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $1364800
View 05Moose's Photo Gallery
Slip indicator
The VSC;
The TRAC;
Of course, I think that's all bullshit (not you RTFM, the manual). I bet if you look up the VSC indicator light, it would say it comes on if there's a problem with the VSC components. But on the 1st Gen Highlanders, many things that trigger the CEL will trigger the VSC light too. Our '05 HL had a sensor wire on the exhaust bumped when being serviced which triggered the CEL and VSC lights. Searches on the internet confirmed what the dealer told me that the VSC will come on any time the CEL comes on for an emissions sensor like that (it was actually a big problem because people would go over something on the road which would kick up and bump the sensor in turn triggering the CEL and VSC lights). Anyway, I bet there's a specific (or a few types of faults) that automatically trigger the slip indicator light when the CEL is triggered. Because of that, I would only research the code that the CEL triggers and ignore the other one (since it's probably a secondary reaction to the first). Just my .02 (and I could be wrong in this case).
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is online now   Reply With Quote Quick reply to this message
Old 03-27-2012, 08:21 PM   #19 (permalink)
Senior TN Member
RTFM's Avatar
Moose
I don't doubt you on both counts actually......
My (like yours) is ignore the Slip light, and look at the code. In some places in the FSM, I have seen references to lights plus CEL, giving you a better clue, but nothing on this pairing so far.
Most of the indicator lights in the manual gives overly broad BS answers
Old 03-28-2012, 09:57 AM   #20 (permalink)
Gameroom cash: $107700
View TurDonor's Photo Gallery
The slip indicator will usually be associated with a code, but it might be a C-code (chassis) rather than a P-code (powertrain) so make sure whatever code reader you are using can read those.
TurDonor is online now   Reply With Quote Quick reply to this message
Old 05-25-2012, 06:29 AM   #21 (permalink)
View Barcodeguy's Photo Gallery
My CEL and VSC came on after messing around with some connectors by the drivers side kick panel trying to find the reverse light wire for a back-up camera on my 2010. I assume since the codes are now stored in the computer the only way to clear them is with an OBD II diagnostic tool. Someone mentioned try disconnecting the battery, but I think since they are already stored, disconnecting the battery will not do anything. I guess I will be making a trip to Advance Auto to borrow their OBD II tool again.
Barcodeguy is offline   Reply With Quote Quick reply to this message
Old 05-25-2012, 12:27 PM   #22 (permalink)
I did not have to do anything. Got in the truck this morning and both lights are off now.
Old 05-25-2012, 09:46 PM   #23 (permalink)
Gameroom cash: $171250
View integlikewhoa's Photo Gallery
Originally Posted by Tacoman82 View Post
Hello, I am new to TN and normally post on TacomaWorld. I have a similar issue, in that, the engine check and slip indicator lights are on. I know the problem with the engine check light has to do with evap and is related to an issue with my gas cap. Does anyone know why the slip indicator would come on along with the engine check light. I clear the codes and that lasts 3-4 days and the lights come back on simultaneously. It occurred initially while driving in a heavy downpour near my home in Austin, Tx.
Can't tell you why Toyota as both lights come on, but I can tell you that if you fix the problem your already know about and have ignored...... it would fix both your lights.
'06 Tacoma Double Cab 4x4, Auto , TRD-Off Road, Silver. BHL mod and removed emblems
Fabtech 6" lift W/Dirtlogic coilovers, 3" front spacer, 3" bodylift, 20" ProComp 5936 W/35" Toyo OpenCounty M/T tires, Camburg UCA's, longer SS brake lines.
integlikewhoa is offline   Reply With Quote Quick reply to this message
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Toyota Nation Forum : Toyota Car and Truck Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
If you do not want to register, fill this field only and the name will be used as user name for your post.
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
Log-in
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
You may post new threads
You may post replies
Powered by vBulletin® Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
