4x4 indicator light blinks HELP! - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 11-15-2012, 10:24 AM   #1 (permalink)
igi-man's Avatar
View igi-man's Photo Gallery
Hello everyone!
couple of days ago i start to have this problem, i went camping and when i shifted to 4x4 hi the light start blinking, wouldn't not stay solid, but i could tell im in 4x4 mode, when i got to the spot i tried to turn it off and nothing happens, light would just blink!! the only way i could turn the light off is switch to 2wd and turn the key off and back to ignition position...
so when i came home i took the front actuator apart, i was amazed how much water was inside
so i cleaned it and test it, motor works and everything looked good to me. so i put everything back together, same thing - light blinks, so i ignored it for awhile. then after few days i tried to go into 4x4 and i noticed that dash swith did not respond at all. the only way i could go into 4x4 is when i shut the car off and put switch into 4x4 and then i start the car, light blinks but im in 4x4 hi....since i have 59K miles i took to the dealer with a small hope that they will cover it, they charged me $120 bucks to find the problem, and here what they told me: up to 60K miles warranty only covers drivetrain like transmission, driveshaft, differential, but not electronic problems. Damage was for $1700 bucks. they told me to change two sensors on transfer case and front differential actuator, i changed two sensors because they were $70 and $100 bucks, that didnt fix anything. another thing i noticed that when i drive faster then 60 mph i hear 4x4 ecu clicks, (started it recently) located under the glove box compartment.
is anyone had a same problem, i would appreciate any suggestions!!!
08 Tacoma 4x4 TRD off road
6" Procomp Lift, Dick Cepek DC-1 wheels.
33x12.5 r17 Nitto Mud Grapplers
Tom Woods drive shaft
Bushwacker flares
Flowmaster Dual Exhaust
http://www.toyotanation.com/forum/signaturepics/sigpic138814_1.gif
http://www.youtube.com/user/mazafuka
igi-man is offline   Reply With Quote
Old 11-15-2012, 11:40 AM   #2 (permalink)
Got Snow?
05Moose's Avatar
Gameroom cash: $1006500
View 05Moose's Photo Gallery
Sounds like you might want to check the signals being sent from the ECU. Read through Geoff's thread as RTFM posted the electrical info:
My turn to ask for help with 4HI / transfer case
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is online now   Reply With Quote
Old 11-15-2012, 02:06 PM   #3 (permalink)
igi-man's Avatar
will try this tonight
Bushwacker flares
Old 11-17-2012, 05:30 PM   #4 (permalink)
igi-man's Avatar
GOT IT FIXED!!!!
i pulled the front actuator back again and inspected one more time and found that contact on motor is bad!!! re-solder the contact and boom works!!!
Bushwacker flares
Old 11-17-2012, 08:56 PM   #5 (permalink)
Got Snow?
05Moose's Avatar
Alright! Love those free fixes!
Old 11-19-2012, 09:52 AM   #6 (permalink)
Senior TN Member
RTFM's Avatar
Gameroom cash: $414962
View RTFM's Photo Gallery
You can send a share of the $1700 you saved to TN care of..........
06 DC LB, 4x4, Speedway , TRD Sport w/ Tow, JBL 6CD w/ Grom to IPod, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Hood Struts, Scangauge, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Toyo Open Country AT tires
RTFM is offline   Reply With Quote
Old 11-19-2012, 10:25 AM   #7 (permalink)
needamog's Avatar
Gameroom cash: $207265
View needamog's Photo Gallery
If you had water in the actuator, you may want to check all the fluids in axles, transfer case, etc. also.
Maybe BACKING the boat into the water would help reduce water damage
Brad B.
Durango, CO
07 DC 4x4 offroad
1981 Unimog 416Doka
needamog is offline   Reply With Quote
Old 11-19-2012, 11:13 AM   #8 (permalink)
igi-man's Avatar
i wish i could, but that $1700 will go into rock sliders and other cool stuff that was planned long time ago
i recently changed all the fluids include transmission, transfercase, rear axle and front, thanks for advice.
Gas tank fluids i change periodically
Bushwacker flares
