Timing Chain Cover Starting to leak - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 2nd Generation (2005+)
2nd Generation (2005+) Discussion area for the 2nd generation of the Toyota Tacoma
Old 01-16-2013, 09:26 PM   #1 (permalink)
View Belliott's Photo Gallery
The dealer pointed out my timing chain cover is starting to leak where it meets together. Is there a cheap fix? I know it's aluminum so I must be careful about what is applied on it. He said "its very small and just keep changing the oil every 5k and keep my eye on it". Any suggestions?
The truck is an 07 4wd TRD with 215k yep she's been driven.
Belliott is offline   Reply With Quote
Old 01-16-2013, 09:45 PM   #2 (permalink)
TN god
Gameroom cash: $101465
View Marty McFly's Photo Gallery
Well, you could fix it... or just keep an eye on it and change the oil ever 5k miles.
If you want a cheap fix, I guess you could just put a bead of RTV around the cover, but thats not really fixing anything.
Marty McFly is offline   Reply With Quote
Old 01-17-2013, 08:48 AM   #3 (permalink)
Gameroom cash: $104400
View TurDonor's Photo Gallery
I'd let it seep too. Wipe it off now and then, or think of it as rust prevention.
If you want to try to force some gasket stuff in there, you can try, I don't think it will last long. I'd use something like Permatex Ultra Black RTV silicone gasket maker.
The real fix is to remove the timing chain cover, clean and reapply the gasket maker. That's tedious, you have to remove all the stuff on the front of the engine, and the top including the valve covers, before you can get the cover off.
TurDonor is offline   Reply With Quote
Old 01-17-2013, 08:52 AM   #4 (permalink)
Senior TN Member
dl1027's Avatar
Gameroom cash: $142125
View dl1027's Photo Gallery
How about trying to re-torque the bolts?
'07 Tacoma Silver DC PR SB SR5 V6 AT TP LSD
dl1027 is offline   Reply With Quote
Old 01-26-2013, 06:05 PM   #5 (permalink)
View SilverSportPreRunner's Photo Gallery
Isn't there a tsb for the timing cnain cover leaking on the pre-2008 V6? Changing the gaskets is a major ordeal not to be taken lightly. Search and you will find others with this problem.
SilverSportPreRunner is offline   Reply With Quote
