Whirring and whining noise, 2007 tacoma, v6, ~120k miles - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 3 Old 04-20-2017, 10:27 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Cold weather brought with it some new sounds from my truck. It started out as an intermittent whirring noise, occasionally whiny, then it became more consistent, and is getting worse more quickly. I couldn't figure what it was by listening with the hood up, so, I brought it to my mechanic. They diagnosed it as a bad alternator (bad alternator bearings) and recommend replacement as well as a new belt. I'm going to call the dealer with my vin to SEE if I have the towing package tomorrow, but I don't see a tranny cooler. Will attempt the alternator install this weekend
Seth Hills is offline
post #2 of 3 Old 04-20-2017, 11:38 PM
Got Snow?
05Moose's Avatar
Quoted: 1129 Post(s)
Easy way to check for towing package is to look for the oil cooler equipment. Just look for the unit with the two lines under the oil filter.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is offline
The Following User Says Thank You to 05Moose For This Useful Post:
BamZipPow (04-21-2017)
post #3 of 3 Old Yesterday, 08:13 AM
Senior TN Member
Quoted: 173 Post(s)
Also, could be one of the other bearings the belts wrap around. At least one of those is not a closed bearing that uses a rubber seal to keep out moisture but rather has a metal shield that frankly is not very water resistant. At the age and mileage of your rig its probably worth considering.
Taco'09 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
