2011 Tacoma Headlight Moisture - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 5 Old 05-13-2017, 11:40 AM Thread Starter
Quoted: 54 Post(s)
(Thread Starter)
I had to change my lamps in the headlights recently.
Boy, what a goofy way to mount the bulbs, using that stupid spring clip.
Even after clipping them in, they still seem loose and one of them developed moisture in the headlight.
Possibly the rubber seal was not fully seated? I took it apart, dried it out and re-installed the bulb, and re-seated the rubber seal.
I hope this solves the moisture problem.
Has anyone else had issues with this?
2015 Camry XLE, 4 Cylinder
2011 Tacoma Double Cab, TRD Off Road.
tonyreo is offline
post #2 of 5 Old 05-13-2017, 11:59 AM
short-throw dipstick
Quoted: 809 Post(s)
I had this problem on a different car ('01 Honda Insight) with 9004 bulbs. Problem was exactly that, the rubber cup seal wasn't seated all the way.
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k CRASHED BY "FRIEND"
00 Camry 5S-FE 187k
99 ES300 243k ALMOST DONE!
01 ES300 151k
01 Insight 137k
insightbrewery is offline
post #3 of 5 Old 05-13-2017, 03:26 PM
Got Snow?
05Moose's Avatar
Quoted: 1199 Post(s)
And if the bulb is still loose, the clip might need to be bent a little to add more force.
'05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s, 12/3/04
Mods: Fog, Map/Dome Light, Illuminated 4wd Selector Switch,
DIY Washable Cabin Air Filter (Moose Filter Mod) | & 2010 Highlander 4WD
05Moose is online now
post #4 of 5 Old 05-18-2017, 10:02 AM
Senior TN Member
RTFM's Avatar
Quoted: 89 Post(s)
It is possible to get the bulb in place, and clipped down, with the bulb installed incorrectly. My first change, the ears on the bulb were rotated wrong, and it still clipped in. Light pattern was odd was how I knew I fouled up.
06 DC LB 4x4 Speedway, TRD Sport w/ Tow, JBL w/ Grom to IPod / Aux / BT, Roof Rack, Weathertech bug deflector & floormats, Access LE tonneau, Clifford 10.5x alarm, Homelink Mirror, Ultra Grinder Wheels, Michelin LTX MS2 tires
RTFM is offline
post #5 of 5 Old 05-20-2017, 12:59 PM Thread Starter
Quoted: 54 Post(s)
(Thread Starter)
More Headlight Problems Now
Ok, in keeping with my "luck" I was trying to bend the spring clip a bit and the mount that holds the clip to the headlight broke off.
Goodbye headlight
I see Amazon sells an aftermarket replacement:
https://www.amazon.com/TYC-20-6577-0...ype=automotive
It's ~$50 and seems to have good reviews.
Anyone have any input on this headlight?
tonyreo is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
