Negative Battery Cable Replacement? - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 21 Old 08-13-2007, 11:48 AM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
How do you know when you have to replace your negative battery cable? I ask because my negative battery cable is growing crystal-fur on it and I wonder at what point it will corrode and go bad. When it goes bad where is the best place to get a new one? I called Advanced Auto and they said that, because it is a Toyota I would have to go to a dealership and that to me is the equivalent of Jerry seeing Newman after a bad day.
What are your thoughts? (Forum Unite!)
Xander Crews is offline
post #2 of 21 Old 08-13-2007, 11:58 AM
SOOPER DOODIE!!!
jdwilson's Avatar
Quoted: 2 Post(s)
put some coke on it.
2014 Tacoma TRD Sport Long Bed
Supercharged!!!
jdwilson is offline
post #3 of 21 Old 08-13-2007, 12:01 PM
2012/14 Stanley Cup Champ
zmtnbik's Avatar
Quoted: 7 Post(s)
How old is your truck? Chances are it's not old enough to worry about if you are posting in a 05+ forum.
As previous poster mentioned, you can poor coke on it, or even better, water; yes water.
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
zmtnbik is offline
post #4 of 21 Old 08-13-2007, 12:12 PM
I hate hippies.
tacogrande's Avatar
Quoted: 0 Post(s)
baking soda neutralizes sulfuric acid. Use some with water and a wire brush for a shiny new connection. Any generic cable will work as a replacement when this one corrodes through in 30 years as long as it's attached to the block and the body somewhere.
tacogrande is offline
post #5 of 21 Old 08-13-2007, 12:12 PM Thread Starter
Quoted: 4 Post(s)
(Thread Starter)
It's an '05
post #6 of 21 Old 08-13-2007, 01:08 PM
SOOPER DOODIE!!!
jdwilson's Avatar
Quoted: 2 Post(s)
put some coke on it and not cocaine, coca cola. i'm serious. it will eat the corrosion off, then just spray it off with a hose.
Supercharged!!!
jdwilson is offline
post #7 of 21 Old 08-13-2007, 02:21 PM
EzriderGA's Avatar
Quoted: 0 Post(s)
As someone already suggested, baking soda/water mixture. Apply with a throwaway brush and rinse with water. Next you need to put a thin layer of vasaline or grease all over the post and cable and it will help protect the area from future buildup. Been doing it for years and works like a champ. ez
EzriderGA is offline
post #8 of 21 Old 08-13-2007, 02:32 PM
Pb
Surfing TN via iPhone
Pb's Avatar
Quoted: 0 Post(s)
iTrader Score: 15 reviews
No need to replace it. Just clean it! AutoZone has battery terminal cleaner, and also a spray protectant.
Personally, I use electrical grease from Lowes. It's made to protect electrical connections from moisture. It also improves conductivity, unlike dielectric grease. Dielectric grease should only be used to cover a connection that's already made. Don't put it between a connection.
Pb is offline
post #9 of 21 Old 08-13-2007, 03:17 PM
Georgia
Jeddak's Avatar
Quoted: 1 Post(s)
Obviuos and stupid, but.... disconnect the cable before cleaning. Baking soda neutralizes acid, so keep it it way from the battery.
+2 on electric grease, it will keep corrosion awy, and connections clean. NAPA, Autozone, Lowe's all have it.
Impeach Chief Rat Roberts now!
Jeddak is offline
post #10 of 21 Old 08-13-2007, 04:43 PM
This Space For Rent
humanoid's Avatar
Quoted: 560 Post(s)
Good suggestion there, Pb, didn't know that. Man, learn something new everyday!
humanoid is offline
post #11 of 21 Old 08-13-2007, 06:04 PM
Hi-Miler
Quoted: 0 Post(s)
wd-40 works......CRC Brakekleen works also
most people have 1 or both handy in their garage
while you are at it
take your cables loose
use a wire brush to clean both
pos & neg clamps & posts
will keep you running longer & better
no matter what
better to do now than in winter
that same buildup you see now keeps your batt
from being optimized
a little spray & brushing now
saves you big time later
good luck
"every miles a memory......."
toy-taco is offline
post #12 of 21 Old 08-13-2007, 06:07 PM
Pb
Pb's Avatar
Quoted: 0 Post(s)
Yup.
"A dielectric, or electrical insulator, is a substance that is highly resistant to the flow of an electric current."
Think of it like electrical tape. Only use it overtop of the connection.
Pb is offline
post #13 of 21 Old 08-13-2007, 06:11 PM
Pb
Pb's Avatar
Quoted: 0 Post(s)
Be careful with that Brakleen. It usually sprays out forcefully. Your battery is mounted near the fender and headlight. Brake cleaner is the ultimate destroyer of all things plastic and painted, which would include your headlight and the paint on your fender.
Pb is offline
post #14 of 21 Old 08-13-2007, 07:52 PM
Quoted: 0 Post(s)
Yup.
DAM! I've been watching mechanics for yrs squeeze that stuff into the end of a spark plug boot and put it on the spark plug! I've even done it myself. Now I know better.
08 Sienna Limited AWD
07 Taco DC TRD OR
MDTRD is offline
post #15 of 21 Old 08-13-2007, 08:00 PM
Go Sharks!!!
SJlittlefoot's Avatar
Quoted: 0 Post(s)
lol me too, i've used battery post grease to protect my battery post in previous cars, kinda purplely thing, i dunno if it dielectric or electric. I gotta check cause i'm planning on using that to prevent corrosion on my battery and cables
06 Tacoma D-cab Prerunner TRD Off-Road
http://www.cardomain.com/ride/2284057
SJlittlefoot is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
