2008 Tacoma Oil Change - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 14 Old 02-18-2008, 10:30 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA 2008 Tacoma Oil Change
You guys have inspired me to step out of my comfort zone and start working on my Tacoma. I don't normally do this so I will preface this with that.
I just changed my oil on my 08 Tacoma (4.0 liter) for the first time. I made much more of a mess than I had hoped. So I have a few questions about the whole procedure.
1) Reading the dip stick. There are two dots on the end of the dip stick. Where on the dip stick should the oil be when fulling filled? I read through the owners manual, search online but couldn't find what I was looking for.
2) When taking off the oil filter, there was still a lot of oil in it and it spilled. I have cleaned it up which a bunch of rags, etc. Are there any techniques to minimize the mess that is created?
Thanks for getting back with me.
Taco2Drive is offline
post #2 of 14 Old 02-18-2008, 10:38 AM
Stupid is stupid does
lotust's Avatar
Quoted: 2 Post(s)
If you search "oil change" in topics only in the 2005+ section you will get more info that you can shake a stick at.
here is one
First oil change, critique please...
295/65/18 Goodyear Duratracs:2.5" lift in the front with 1" rear Block
JBA single exhaust:HID's W/Led's inside:Nfabs
E&G grill insert:ARE Z topper:Overhead DVD for my son:Front DVD for me
lotust is offline
post #3 of 14 Old 02-18-2008, 10:41 AM
Quoted: 0 Post(s)
1) Anywhere between the two should be fine. If you put in the recommended amount it should be about 3/4s of the way up between the two dots. Perfectionists make sure it's right on the top dot. Doubt there's any difference there.
2) Let it drain longer? And, underneath that small silver cup just beneath the filter there is a drain valve. Just get a large mouth bottle or large yogurt container underneath it and pull the rubber piece off the end. Then unscrew the filter and let it drain into that cup...it should funnel right into your container. Hope that helps.
You will most likely get a little bit on your fingertips from pulling the rubber piece, but that should be all.
zippo44 is offline
post #4 of 14 Old 02-18-2008, 10:48 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you. I think I needed the quotes.
here is one
post #5 of 14 Old 02-18-2008, 10:50 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank you. I thought I had read something about this in the past but couldn't find it again.
Thanks for a quick response. You have put my mind at ease.
r/Jim
post #6 of 14 Old 02-18-2008, 10:57 AM
2012/14 Stanley Cup Champ
zmtnbik's Avatar
Quoted: 7 Post(s)
Congrats on NOT removing your tranny drain plug when changing your oil
Trust me...it's happened!
2006 4x4 Access, V6, 6spd, TRD Off-Road, tow pkg. Donahoe Co's, TC UCA's, Dakar leafs, 5125's in the back and u-bolt flip kit. TRD exhaust, CAI. URD MAF calibrator. 17x9's, 285/70/17 BFG MT KM2. Locker-mod, fog mod and console vault.
zmtnbik is offline
post #7 of 14 Old 02-18-2008, 11:15 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
You mean the engine oil isn't red?
post #8 of 14 Old 02-18-2008, 11:16 AM
Man in Blue.
Ice|Burn's Avatar
Quoted: 0 Post(s)
Does this ring true for both manual and auto? I have yet to get under a Taco so I can't go look at mine because it's not here yet.
Ice|Burn is offline
post #9 of 14 Old 02-18-2008, 11:19 AM
Theatre Nerd Person...yea
Sony's Avatar
Quoted: 0 Post(s)
^^^ No I've never head of it happening with the manual. I think the manual's drain plug is on the side instead of the bottom like the auto is so it's more difficult to mistake.
2006 Toyota Tacoma DCab Long Bed SR5 V6 5spd Auto 4x4
Tow Package, 6 CD Changer, Rear Limited Slip Differential, 16" Alloy Wheels
Silverstar H4 Headlamps and
Silverstar 9005 Foglamps, Bed Storage Utility Lock Mod, Redline Tuning Gas Hood Struts, Roll-N-Lock M-Series Retractable Tonneau Cover
Sony is offline
post #10 of 14 Old 02-18-2008, 01:44 PM
Quoted: 0 Post(s)
To clean the spilled oil, use kitty litter to absorb it.
mxer is offline
post #11 of 14 Old 02-18-2008, 01:47 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I must say that I am very pleased with the oil change. I switched from dino to Penzoil Platinum 5w30. The engine runs smoother and quieter and feels a lot better and responsive. This is my second oil change at 5500 miles. So we'll see how long this "feels" this way before the next change.
post #12 of 14 Old 02-18-2008, 08:24 PM
Georgia
Jeddak's Avatar
Quoted: 1 Post(s)
Sand the dipstick with 150 grit sandpaper. Between the marks, across the stick. It will make oil reading much easier. Install a Fumoto drain valve--no more bolts to undo to drain the oil.
Impeach Chief Rat Roberts now!
Jeddak is offline
post #13 of 14 Old 02-18-2008, 08:39 PM
Softball God
WilsonTheDog's Avatar
Quoted: 35 Post(s)
That's what I use. Just did it yesterday, actually. That oil flows out of there like a damn fire hose so unless you cover everything in the immediate vicinity, you're going to get some spillage. I think I'm going to switch to a bucket or something with higher sides than my drain pan next time.
Eric
2007 Toyota Tacoma
PreRunner SR5 V6 DC SB
2014.5 Toyota Camry SE I4
WilsonTheDog is offline
post #14 of 14 Old 02-18-2008, 08:56 PM
One with the Force
maxama10's Avatar
Quoted: 0 Post(s)
No, I think what happened was someone confused the oil pan for the tranny pan. Manual transmissions do not have the pan, therefore you shouldnt get confused. On the manual there is just a bolt up against the tranny housing.
Hope that helps.
maxama10 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
