4.0 V6 Chain or Timing Belt ? - Toyota Nation Forum : Toyota Car and Truck Forums
Tacoma 2nd Generation (2005-2015) Discussion area for the 2nd generation of the Toyota Tacoma
post #1 of 18 Old 07-04-2009, 09:01 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
Does the 4.0 V6 have a timing chain or does it have a belt? Thanks, Dave
Snellville-Dave is offline
post #2 of 18 Old 07-04-2009, 09:17 PM
Future Banned Member
tonyspin's Avatar
Quoted: 0 Post(s)
05 and up taco has a chain
tonyspin is offline
post #3 of 18 Old 07-04-2009, 11:03 PM
Man in Blue.
Ice|Burn's Avatar
Quoted: 0 Post(s)
One of the MANY reasons why I bought the V6 was because of the chain.... Belts make me nervous....
Ice|Burn is offline
post #4 of 18 Old 07-05-2009, 12:37 AM
Official TN User
RuneRules's Avatar
Quoted: 0 Post(s)
So true, chains are supposed to last longer than the belts.
RuneRules is offline
post #5 of 18 Old 07-05-2009, 12:45 AM
Theatre Nerd Person...yea
Sony's Avatar
Quoted: 0 Post(s)
Chains DO last longer than belts...there is no "supposed to." If it doesn't last longer then a belt then there was a manufacturing defect in the chain itself. It's metal versus rubber, of course metal will last longer. Chains also can't jump timing and should in most cases last the entire life of the engine without the need to be replaced, they also don't stretch much if at all.
2006 Toyota Tacoma DCab Long Bed SR5 V6 5spd Auto 4x4
Tow Package, 6 CD Changer, Rear Limited Slip Differential, 16" Alloy Wheels
Silverstar H4 Headlamps and
Silverstar 9005 Foglamps, Bed Storage Utility Lock Mod, Redline Tuning Gas Hood Struts, Roll-N-Lock M-Series Retractable Tonneau Cover
Sony is offline
post #6 of 18 Old 07-05-2009, 01:11 AM
HighTQCummins's Avatar
Quoted: 0 Post(s)
Correct me if i'm wrong but aren't most OEM's now switching to belts for this very reason?
2007 ACLB, O/R, V6, 4x4. FL Mod, 13% front, 5% rear, 5% 9" strip, 2.5kw system, HC600, PC1700T, TRD CAI, 60w strobes, 4 amber 3LEDs, firestik, Timbrens, Leaf TSB, N-Fab Bar, 2 500ff's, 2 LF 170s, 4300k HIDs, no muffler, Grover 1510, 5100s @ 1.85, AT/KO 265/75/16
HighTQCummins is offline
post #7 of 18 Old 07-05-2009, 03:46 AM
ASE Master Tech
Quoted: 0 Post(s)
Nope, belts are just cheaper to produce.
WCTacoTech is offline
post #8 of 18 Old 07-05-2009, 09:27 AM
Quoted: 0 Post(s)
belts also bring the customer back at 90-100k for a $700+ replacement service...
Wise Men STILL seek Him!
Axxis8203 is offline
post #9 of 18 Old 07-05-2009, 09:57 AM
Senior TN Member
Quoted: 0 Post(s)
The I4 has a chain too.
2005 Impulse Red 4x2 Access cab 2.7L 5-speed SR5.
worthywads is offline
post #10 of 18 Old 07-05-2009, 09:58 AM
Quoted: 0 Post(s)
Huh? Sorry but you're wrong on most points. Chains do wear, and as they wear they stretch. All of them. This is why they have oil pressure actuated chain tensioners to compensate for that stretch. They also vary in quality. There are single, double and triple roller chains. This will determine when the chain needs to be replaced, usually between 60,000 and 120,000 miles (belts are pretty much spent after 60,000 miles, so yeah, chains do outlast belts.) Timing chains can jump timing. It happens when the oil feed to the chain tensioner becomes clogged and the tensioner ceases to work allowing the timing chain to become slack, although the chain is likely to snap when it happens, they do jump time. Happens all the time to abused motors.
bob857 is offline
post #11 of 18 Old 07-05-2009, 02:41 PM Thread Starter
Registered User
Quoted: 0 Post(s)
(Thread Starter)
I've got a 2003 Camry I4 with a chain and have had a 1996 Corolla with a belt that I had changed every 60,000 miles. Just hoping also that the new 2.7 liter engine for the Highland gets in the 2010 Tacoma, because I want a I4 with auto and 4wd.
post #12 of 18 Old 07-05-2009, 04:36 PM
ASE Master Tech
Quoted: 0 Post(s)
Gotta disagree with you there on your mileage numbers. Depending on manufacturer, belts are rated for between 60k and 100k miles. Chains are alot more durable and usually are 120k miles or longer. Typical chain replacement on 22re motors was near 200k miles after the chain guide broke and started sawing through the timing cover. Chains generally last the life of the motor except in certain circumstances (Nissan and their VQ40 motors, 80s Ford V8s with plastic teeth on the timing gears) Not saying the chain is invincible but they are alot stronger than you give them credit for.
post #13 of 18 Old 07-05-2009, 05:27 PM
Quoted: 0 Post(s)
Gotta disagree. Seen it with my own eyes. Fixed them with my own hands. Now if you willing to trash the motor, fine go for the absurd mileage ("Typical chain replacement on 22re motors was near 200k miles after the chain guide broke and started sawing through the timing cover.") or you can be responsible and change the chain out at 120,000 miles - before it wears through anything. The only reason not to is the $$$.
bob857 is offline
post #14 of 18 Old 07-05-2009, 06:36 PM
ASE Master Tech
Quoted: 0 Post(s)
That's if you wish to do a chain R&R as preventative maintenance. You could tell when the guide broke and it was time to change out the chain and that usually was around 200k miles. It rarely trashed the motor, just required replacing the chain, tensioners, timing cover and an oil change and coolant fill. Granted it is a good idea to try and avoid that damage but 120k is really premature.
post #15 of 18 Old 07-06-2009, 06:53 AM
Completely Numb
NOhara24's Avatar
Quoted: 0 Post(s)
I have an '06 with an '05 build date. I've looked all over my motor and never saw a chain. Do I just have a belt then?
2006 super white Toyota Tacoma TRD Sport AC (19.81 MPG average)
K&N intake w/ AEM dryflow
Flowmaster Dual Exit Exhaust
Pioneer AVH-P3100
NOhara24 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > Tacoma 2nd Generation (2005-2015)
User Tag List
Linear Mode Linear Mode
Back
