Oil Change/ Prius - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Prius Forum
Prius Forum The original hybrid from Toyota... the Prius! Discussion area for everything about it.
Old 10-17-2005, 11:56 PM   #1 (permalink)
View digger08's Photo Gallery
Oil Change/ Prius
Just wondering......
If an oil change is performed on a Prius, it is typical to perform an RPM check on most vehicles - this is to say that the RPM is raised to pressure the oil filter and check for leaks.
As the Prius, does not engauge the gas engine until 80Km's - does this require a road test to check that pressure is sufficient? or is there a way to do this without road testing the vehicle?
Is priming the filter prior recommended as well, to avoid vapor or air locks at that speed, when the gas engine engauges?
Inquiring mind wants to know.......
Digger08
Digger08
Lexus IS300
01' Onyx/ Arm Rest/ 02 Tails/ Xpel/ Carson Tuned/ Eibach/ Ltuned 18's/ Injen Intake
GReddy EVO/ TeCk grounding kit/FigProprod/DashTray/ LSD/Ltuned Sways
digger08 is offline   Reply With Quote
Old 10-18-2005, 02:52 AM   #2 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
I'll post your question on PriusChat.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
Old 10-18-2005, 01:06 PM   #3 (permalink)
TMS Prius Expert
Here's one by jayman
You mean you want to start the ICE to check for leaks, right?
Get into the car and Power On. Wait until it goes to Ready. Then floor the gas pedal. The ICE should instantly start. Once it starts, take your foot off the gas pedal and the ICE will return to its usual "idle" speed. It won't sit there screaming away.
You can then go out to check for leaks.
