steering noise in '03 prius - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Prius Forum
Prius Forum The original hybrid from Toyota... the Prius! Discussion area for everything about it.
Old 03-03-2006, 08:45 PM   #1 (permalink)
View tmoney_1111's Photo Gallery
I have been hearing some noise from the steering column when doing hard turns in my Prius. I figure it needs power steering fluid, but don't know where the fluid goes in. Is the steering fluid container accessible?
tmoney_1111 is offline   Reply With Quote
Old 03-04-2006, 10:53 AM   #2 (permalink)
View Odie's Photo Gallery
03 replaced my steering already
Hi...I had to have the entire steering unit replaced on my 2003 Prius a month ago. Get that checked....the cost was 1, 972 dollars....yep...that is how much it cost. This car, this year 03, is not great....my next story is going to send chills through you......Three days ago a ROD went through the engine block causing a four inch hole in the engine.....this car has 60K on it. Cost of repair? about 8K. Toyota officials are having them tear the engine down to diagnose the cause. They may pay for this but we have not heard yet. We were preparing to buy a RAV 4 next but this has soured us a bit! HONDA? No more hybrids for us.
We complained about a coolant leak to the dealer a few times but they always did the check and change on the oil. A very smart mechanic we discussed this with in Canada said the coolant may have been entering the oil circulation system and destroying the lubrication properties of the oil. When it became bad enough the piston seized and the shaft snapped.
So there you go....I will keep all posted to let you know if Toyota stands by their vehicles.
Odie
Odie is offline   Reply With Quote
Old 10-08-2011, 08:10 AM   #3 (permalink)
View baboonia's Photo Gallery
Prius have no power steering "fluid"
Since 2001, all Prius use electric power steering systems.
2001-2003 had some issues and Toyota finally admitted it with free replacement steering rack until recall, even if out of warranty.
If you previously paid for steering work on 2001-2003, you may be able to get reimbursed. Talk to Toyota corporate office.
Also, Prius have no starter, no alternator, and no timing belt. If anyone tries to sell you these parts for your car run away!
baboonia is offline   Reply With Quote
Power steering noise after flushing/changing the steering fluid Camry 2001 Mark22 3rd & 4th Generation (1992–1996 & 1997–2001) 1 12-26-2005 01:34 PM
2006 Prius Pricing Tideland Prius Toyota News 2 11-08-2005 09:58 PM
Steering Noise taimurakhter Camry & Solara Lounge 8 04-04-2005 09:18 PM
Moaning/squeeling kinda noise when turning (noise in steering column) SolaraTRD General Discussion 4 12-30-2004 02:41 PM
03 camry ticking/clicking noise brianh 5th & 6th Generation (2002-2006 & 2007-2011) 11 09-26-2003 11:24 PM
