Hey Jason, here is all the parts to complete the retriofit (for my 2001 prius):
> Navigation ECU P/N 86841-33060
> Bracket, Navigation ECU No.2 (Left) P/N 86274-47040
> Bracket, Navigation ECU (Right) P/N 86274-47030
> Cover, Navigation ECU P/N 86843-47010
> Disc, Disc Player (DVD Map disk) P/N 86271-33030
> Antenna Assy, Navigation P/N 86860-47050
> Wire, Floor, No.3, W(EMV & Navigation System) P/N 82163-47100
> Screw: For Navigation Antenna x2: P/N 93568-55012
> For Brack to Floor x2: P/N 90119-06390
> For Navigation ECU to Bracket x4: P/N 90153-50012
> For Navigation Cover x2: P/N 90467-14051
> Instrument panel wiring harness with daytime running light P/N 82141-47080
The P/N mught be different for different years. Here is the part list from dealer:
I obtain all my parts from a doner prius which is from ozgrl.com and they are speciallized on parting out wreck prius.
Here is the doner vehicle:
But I think they are out of business since my main battery was dead back in february and there is no response and the site is dead when I try to contact them for a used battery.
Here is a brief procedure:
1. Before do anything, disconnect the 12 battery power first. Then
remove the front seats and the center console, door still plastic
trim, and the whole dashboard.
2. Lift up the front part of the carpet, took out "Wire, Floor ,
No.3" and refit the " Wire, Floor, No.3, W(EMV & Navigation System)".
3. While the dashboard is out, took out the old "instrument panel
wiring harness" and refit the "Instrument panel wiring harness with
daytime running light" and the navigation system antanna.
4. Put everything back together. But put the navigation system first
before put back the passenger seat, then you are done!
If you want more detail decription or wire diagram, let me know and I will try to scan the page from the repair manul for you.....(but give me some time to do that)
The total time for this retrofit (I'm not mechanic, and just follow
the factory manual) is less than 60 hours.
I only took three photo during the retriofit (I should took more).
-Joseph
