Under engine splash guard problem - Toyota Nation Forum : Toyota Car and Truck Forums
Prius Forum The original hybrid from Toyota... the Prius! Discussion area for everything about it.
post #1 of 14 Old 04-14-2012, 10:18 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
So I'm coming home from work the other day when our car starts making some strange noises. After getting to a safe place to inspect it I find the oil change access door has come lose at the front! Well I pull it up on the ramps at home and find the front hinge had broken all the way and the front portion of the door drug off. A call to the dealer where it was bought got me a response of: It's a defective part so just remove the rest of it (the door) and it's all good.I know it's a pain in the ass when time for oil changes but it was put there for a reason, besides it has some insulation on it, maybe for keeping and maintaining oil temp in winter? Any way I ask the service guy if I order one can I install it myself and of course he says yes and then I ask him if it will be free of charge, he says of course not. Is it worth raising my blood pressure over this deal, I will not pay for a new one!
roo
steve almaraz is offline
post #2 of 14 Old 04-14-2012, 02:36 PM
TN Member
Tideland Prius's Avatar
Quoted: 25 Post(s)
If you can somehow prove that the dealer didn't put it back properly and that caused it to hang up on something and break off, otherwise it's unfortunate but you'll have to pay for the part (same thing happened on my friend's Prius except the whole underbody cover came off, not just the oil pan cover)
Tideland Prius is offline
post #3 of 14 Old 04-14-2012, 02:52 PM
Tech1984's Avatar
Quoted: 7 Post(s)
A year ago this TSB came out to address this:
T-SB-0032-11
Some 2010 Prius vehicles may exhibit an engine under cover that has warped at the front edge after oil maintenance has been completed. An updated engine under cover is now available to address this condition.
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle’s in-service date.
P# 51410-12103
There are three types of clips:
• 11 plastic to thin metal (Part No: 90467-07201)
• 2 plastic to thinner metal (Part No: 90467-09227)
• 1 plastic to plastic (Part No: 90467-07166)
Bin wrenchin' on the Yota's since '84
30th anniversary 2014
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
Tech1984 is offline
The Following User Says Thank You to Tech1984 For This Useful Post:
Tideland Prius (12-05-2013)
post #4 of 14 Old 04-14-2012, 04:33 PM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1104 Post(s)
iTrader Score: 8 reviews
The plastic clips can come loose & fall out. I've had the same thing happen to my 09 Corolla & 10 Prius. When they get loose I replace them with some better clips that I bought a NAPA.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #5 of 14 Old 04-14-2012, 09:24 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanx guys, the panel was still attached at the back with the little plastic buttons but hanging down in the front as the not so flexible hinge completely broke clean from the rest of the cover. I do my own oil changes so the fact it is gone doesn't completely upset me, the fact that the service guy automatically assumed I hit something and said it wouldn't be covered by warranty is really what pissed me off!
roo
post #6 of 14 Old 04-14-2012, 10:50 PM
Diehard Rams Fan
If you do replace the part I heat up the crease with a heat gun to make it more flexible before bending it back. You should be fine without it though.
post #7 of 14 Old 04-15-2012, 11:12 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
^Thanx man, I'll probably just leave it as is, the car has been a real life saver the last few months as my wife and I have been carpooling and leaving my Ram 1500 in the drive way. Need that oil from Canada!
roo
post #8 of 14 Old 06-13-2012, 04:33 PM
Quoted: 0 Post(s)
Thumbs down
Same problem wife's 2010 Prius. Dealer was just going to throw that piece away. I suspect it has aerodynamic function at least. I bitched about it (since wife has only had 5 oil changes). There was a recall, but failure happened after warranty. As lame as that is it's not a safety related issue, so they don't have to inform owners. I had them drill four holes on opposite sides of where it formerly hinged and put zip ties through them. I'll probably add a couple more just so it won't be as inclined to catch on something. I guess they've addressed the problem on later models. Lame, but it's $300.00 to replace (since splash guard is all one piece) and Toyota saves big bucks by not stepping up.
zerocarbon is offline
The Following User Says Thank You to zerocarbon For This Useful Post:
Ideaman (06-10-2013)
post #9 of 14 Old 12-04-2013, 10:09 PM
Quoted: 0 Post(s)
T-SB-0032-11
P# 51410-12103
I had this same exact thing happen to me. Dealer tech said same thing "you must have hit something". Dealer has been the only ones doing oil changes. Happened with 46K miles. I have Platinum extended warranty. Would this be covered under that?
threecarowner is offline
post #10 of 14 Old 02-23-2015, 10:45 PM
Quoted: 0 Post(s)
I have the same issue. The splash guard came off while driving. This is due to the defective design since if plastic bends (when changing oil) it will eventually break! We all need to email and document this issue. Toyota is not covering the cost since it is out of warranty. I did however purchased Toyota VSA extended warranty but it still does NOT cover the part. The splash guard is definitely defective so why we should cover the repair. I've contacted Toyota and they said if this is happening to many other owners they will reimburse us for the repair. So please everyone take time to fill out the form and let them know we are not responsible for this DEFECTIVE splash guard.
Please click on the link and let our voices be heard!
http://www.toyota.com/support/#!/app/ask
bounce88 is offline
post #11 of 14 Old 05-13-2015, 10:10 AM
Quoted: 0 Post(s)
Oil/filter access door
Thanks for the link to let Toyota know of our problem. Below is the message I sent, along with 3 pictures.
"This email is in regard to the oil access door not staying in place on the above mentioned vehicle. I've always had the oil changed at the dealership. I'd like to think the service person would've confirmed this door was properly & securely closed. I've read that there are other Prius owners with the same problem/concern. The way the door attaches obviously is a problem. Does Toyota plan on issuing any kind of repair/replacement for this problem? Looking forward to your response."
notmyf150 is offline
post #12 of 14 Old 05-13-2015, 10:47 AM
Quoted: 0 Post(s)
I've emailed Toyota numerous times and went to a Toyota dealership hoping to have them agree with me that it's a defective part. But unfortunately that dealership blame it on me as the cause of damage "going over concrete barriers". I continue to email and call Toyota that its defective, and there are no scrapes on the engine guard itself so the damage is not caused by me but the part. The point of where it breaks off is where they access to engine for oil change. Over time it will break and that's why there's a TSB and the new part addresses the issue. Finally Toyota decides to offer me $200 credit but the replacement cost around $400. I later found a dealership that agreed with me but Toyota still refuse to cover the entire cost. This was a painful and tiring experience but will worth it because that dealership contacted their district manager who paid for my replacement. Good luck and don't give up because why should you be responsible and spend money when is not your fault.
bounce88 is offline
post #13 of 14 Old 05-17-2015, 08:19 PM
Quoted: 0 Post(s)
The splash guard of my 2010 prius came off also while driving. The car was only 1 year old and still under factory warranty. As a technician , the moment I saw this I was convinced that it was due to the defective design as well as weak plastic material. The cover would break after a few oil change.
Unfortunately the service guy from Lane Toyota automatically assumed I hit something, and said it wouldn't be covered by warranty.
I disputed and tried to get it replaced under warranty, but to no avail. Only now I noticed that so many other Prius owners were also experiencing a same problem.
nizora is offline
post #14 of 14 Old 07-17-2015, 09:49 AM
Quoted: 0 Post(s)
I have had to replace my 2011 engine splash guard two times. The first was because of hitting a rubber gater on the road. This time, all I did was take a dirt road to see the Buffalo River. I keep being told it's me. This is very annoying. I have had to replace the right wheel's splash also, and now the left and under. Of course the warranty is gone now. But reading these posts, it woudn't have matter. I am sure there is a defect in the design. Martha C. from Moore, Oklahoma.
Jemar4 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Prius Forum
User Tag List
Linear Mode Linear Mode
Back
