2008 Highlander Hybrid Limited ABS Actuator Assembly - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander Hybrid The first hybrid SUV from Toyota, the Highlander Hybrid!
post #1 of 4 Old 03-19-2017, 09:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 2008 Highlander Hybrid Limited Edition. The ABS Actuator Assembly needs to be replaced. Unfortunately, $3400 is WAY out of my price range. There was a recall on this same part in 06 and 07. If the 08's are having the same problem, why is not covered under a recall as well?
Fleasbaby is offline
post #2 of 4 Old 04-15-2017, 03:50 PM
Quoted: 0 Post(s)
I have no answers for you on this, but am disheartened to see the price of this part. I just replaced my brakes and had the car towed to get the computerized brake bleeding done. Both the tow truck driver AND the mechanic started the vehicle after I asked them not to do it. I was told not to power on the car once I had replaced the caliper or this part would fry. I was told it was $1900 and THAT is out of my price range which is why I had the car towed to a mechanic. The car ran fine for 3 days. Now I have a code saying the actuator is toast. Now you are saying it is $3400 and I am about to freak out. Hoping someone else chimes in here and can help!
ZoeCat is offline
post #3 of 4 Old 06-18-2017, 03:35 PM
Quoted: 0 Post(s)
The ABS accumulator pump of my 2008 Highlander Hybrid base primes for 2 seconds every 5 seconds when the engine is on. Should I replace the whole ABS assembly? The ABS light is not on and the truck still runs good, though.
tychen is offline
post #4 of 4 Old 06-18-2017, 10:40 PM
Moderator
ukrkoz's Avatar
Quoted: 344 Post(s)
I see one for Camry. My Alldata account shows none for HiHy.
Check with dealer.
NEW HYBRID OWNER FAQ ANSWERED HERE:
http://www.toyotanation.com/forum/10...ease-read.html
ukrkoz is offline
The Following User Says Thank You to ukrkoz For This Useful Post:
tychen (06-19-2017)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Highlander Hybrid
User Tag List
Linear Mode Linear Mode
Back
