Is the fan always on? - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander Hybrid The first hybrid SUV from Toyota, the Highlander Hybrid!
post #1 of 4 Old 05-08-2017, 06:02 PM Thread Starter
Quoted: 17 Post(s)
(Thread Starter)
I press the "off" button in the highlander to turn off the air but then I feel a slight breeze come through the vents. I can change the location of the vents but something is always coming through.
Is the vehicle designed this way? Or has my blower motor gone bad?
FunkyFred is offline
post #2 of 4 Old 05-08-2017, 10:24 PM
Moderator
ukrkoz's Avatar
Quoted: 329 Post(s)
If the vehicle is moving, you WILL have slight air pressure through vents. That's why I seldom run blower. I simply set vents to where I want them and let oncoming air flow do the rest. If you want more of passive ventilation, crack window open some on the pass side. It works as suction then and air flows out vents quite well.
NEW HYBRID OWNER FAQ ANSWERED HERE:
http://www.toyotanation.com/forum/10...ease-read.html
ukrkoz is offline
post #3 of 4 Old 05-18-2017, 03:47 AM
Quoted: 61 Post(s)
Try set the recirculation and see if the wind goes away
2017 HL XLE AWD
dchobo is offline
post #4 of 4 Old 05-18-2017, 12:12 PM
Moderator
ukrkoz's Avatar
Quoted: 329 Post(s)
Yeah except that it's not advised to drive with Recirc on for extended time. I forgot the big reason behind that though.
ukrkoz is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Highlander Hybrid
User Tag List
Linear Mode Linear Mode
Back
