Shortchanged with OE Tires? - Toyota Nation Forum : Toyota Car and Truck Forums
Highlander Hybrid The first hybrid SUV from Toyota, the Highlander Hybrid!
post #1 of 6 Old 06-11-2017, 08:03 AM Thread Starter
lloyd123's Avatar
Quoted: 5 Post(s)
(Thread Starter)
I was adjusting tire pressure and setting the TPMS baseline on my new Highlander Hybrid and decided to measure the tread depth with a tire gauge - I measured 9/32". I even tried a second gauge and it was the same. In the past I always got 10/32" with new tires. I looked up Bridgestone Dueler H/L 422 on TireRack and they had the tire listed several times - OE version didn't list depth but non OE version listed 10/32" and was heavier and wider. I think the OE version shortchanged the owners by about 5,000 miles of wear.
EDIT - just realized that TireRack only listed 19" tires for the Hybrid - not updated yet to list 18" on my XLE for 2017. Looked up the 18" for the non hybrid version and the same results for the tread depth but interestingly they have the OE version as being slightly wider.
2017 Highlander Hybrid XLE Alumina Jade Metallic
lloyd123 is online now
post #2 of 6 Old 06-11-2017, 04:28 PM
Moderator
ukrkoz's Avatar
Quoted: 345 Post(s)
All you need to do is to go to a tire store and measure a new tire of same kind there. You either have the case, or you do not. Fair enough? I doubt Toyota orders some sort of special shaved down tires from Bridgestone. But I know lumber at Home Depot is never length specified. Or width. or thickness.
NEW HYBRID OWNER FAQ ANSWERED HERE:
http://www.toyotanation.com/forum/10...ease-read.html
ukrkoz is offline
post #3 of 6 Old 06-11-2017, 06:46 PM Thread Starter
lloyd123's Avatar
Quoted: 5 Post(s)
(Thread Starter)
Well I'm not going to loose any sleep over this but I do believe that Bridgestone/Firestone makes a special version of the Bridgestone Dueler H/L 422 to be used as OE equipment on the Highlander Hybrid.
If you go to the Bridgestone/Firestone website and look up their information on the Bridgestone Dueler H/L 422 for size P245/60R18 they have it listed as having a speed rating of H. The same Bridgestone Dueler H/L 422, size P245/60R18 that are on my XLE only have a speed rating of T which is exactly what Toyota specifies as listed in the Owner's Manual. So it would appear that Toyota does order a special OE version with a lower speed rating and, according to my measurements, a little less tread.
Again, I'm not going to demand to be compensated for a measly 1/32" of tread - just thought it was noteworthy.
post #4 of 6 Old 06-11-2017, 07:25 PM
Moderator
ukrkoz's Avatar
Quoted: 345 Post(s)
Of course. But you said in your post that or version shortchanged you 5000 miles of warranty or miles driven. Can't see from the phone.
So I'd go to a store, find same tire, use same gauge and take same measurement.
Then you either have case and talk to toyota or not. That's only fair.
For example I observed that my speedo on TCH is 4 miles fast. What can shortchange the warranty. But it is within 5 miles range allowed by NHTSA and somehow odo is accurate so I had no case.
Just saying. As we all like and respect our yotas.
ukrkoz is offline
post #5 of 6 Old 06-12-2017, 10:35 AM Thread Starter
lloyd123's Avatar
Quoted: 5 Post(s)
(Thread Starter)
I don't think Toyota would have any liability in this as they only offered to supply a T rated P245/60R18 tire - not any specifics as to tread depth or to be compared with another version that Bridgestone sells to the public. Toyota offers no warranty on the tire but Bridgestone does so it would be interesting to see how they would prorate a tire that has a defect - would it be based on 10/32" or 9/32" tread? I sent an email to them asking this question - let's see if I get a reply.
By the way - I'm retired and recovering from recent rotator cuff surgery so I really have nothing else to do except waste time on the computer.
post #6 of 6 Old 06-12-2017, 10:52 AM
Moderator
ukrkoz's Avatar
Quoted: 345 Post(s)
Now that I'm back to PC, not phone.
It's simple matter of principle.
And no, Yota won't have any liability. Now that I finally re-read your post.
Of course it will. They want you buy more, not less. it's business.
But now that you are retired and have time... Why not to actually check on tires? Just as educational experiment?
ukrkoz is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Highlander Hybrid
User Tag List
Linear Mode Linear Mode
Back
