Too bad the HiHy doesn't have EV Drive mode (forced EV mode). Well, you have to let the engine come on to warm up, then it'll shut off after it's done (assuming your heater's off, otherwise it'll continue to run). Or, you can shift to drive, move in EV before the engine comes on and once you have enough speed, shift to neutral. As long as it's in neutral, the engine won't come on at start up.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
