Satellite Radio - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Toyota Highlander Hybrid
Toyota Highlander Hybrid The first hybrid SUV from Toyota. The Highlander hybrid!
Old 03-09-2006, 09:37 PM   #1 (permalink)
View lennyk's Photo Gallery
Satellite Radio
Has anyone used the Satellite radio kit from Factory Interactive? Wanted to know installation experience and if the kit is worth it.
Thanks,
Lenny
lennyk is offline   Reply With Quote
Old 03-11-2006, 09:18 AM   #2 (permalink)
View 6eye's Photo Gallery
hi, I installed the xm version. Is the kit worth it? I'd say yes. I explored this kit, vs a surface mount type, which is less costly, not hard wired and less integrated. I figured I wanted a more permanent integrated solution and selected the FI, and that solution is higher in cost. As far as the installation goes, if you are handy, logical, patient, and have common sense with wiring and parts, the installation does take about 3 hours and goes well. I will say that it seemed intimidating to pull apart your interior car panels, pull the radio out, see your car in pieces, trim disconnected, hook it up, then put everything back. (watch the DVD first, then you can tell if you can do it) Everything did go back together perfectly, and the radio works. I'm really glad I did it.
6eye is offline   Reply With Quote
Installing a factory satellite radio in a Highlander brucep Toyota Highlander Hybrid 9 08-20-2007 10:24 PM
Installing a factory satellite radio in a Highlander brucep 1st Generation (2001–2007) 2 02-02-2006 10:19 AM
Any Satellite radio for 05 corolla jsbaker Archived Corolla threads 0 10-05-2005 10:09 AM
FS: Delphi XM MyFi Portable Satellite Radio Unit **MINT** 95CamBoy Non-Automotive 2 05-22-2005 04:25 AM
