Hybrid Charging System - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Toyota Highlander Hybrid
Toyota Highlander Hybrid The first hybrid SUV from Toyota. The Highlander hybrid!
Old 05-19-2006, 06:44 PM   #1 (permalink)
View haydenlake's Photo Gallery
Can anyone give me a rundown on how it works (how the 12v charges) and how much current I can draw off of the bat (for a stereo) without messing something up.
any info is appreciated
haydenlake is offline   Reply With Quote
Old 05-29-2006, 02:37 PM   #2 (permalink)
Iceman91's Avatar
View Iceman91's Photo Gallery
Wink
Stereo should not mess anything up.
2006 Toyota Highlander Hybrid Limited
Eclipse DVD/CD Indash
JBL Pro Mids & Highs Pheonix Gold Tantrum 600 x 4
Kicker L7 15 Dual 2ohm (custom ported enclosure)
Kicker KX1200 = 150.4 db (on dash)
Iceman91 is offline   Reply With Quote
Old 06-18-2006, 06:43 AM   #3 (permalink)
View eggehad's Photo Gallery
Aux Battery Current Draw
I can't say for sure, since the HH comes with a glass mat battery (recharge < 5A) and I don't have any Toyota technical documentation. But before my big "boom-boom" upgrade, I load tested mine, with the inverter on and off.
With the inverter off the battery tested out at ~35AH (limited loading). As an aside, if you load test it, like a standard 24 or larger LeadAcid battery, it will test at only ~15-20 A/hr!
With the inverter ON, battery voltage is fixed at 13.8V (since it is derived from the big battery) and at over 65A loading, I noticed no variation. Since this is what I needed for my amplifier, I stopped there. Note, don't even think of drawing that kind of current without the inverter on though. The cheesy battery they use will just dry out. Fortunately, it isn't that hard to modify the battery mounting bracket to fit a real auxiliary battery in there...
Bottom line is that Toyota doesn't expect the battery itself to supply much power, rather, it is primarily used to stabilize the electronic converter- and to run the standby electronics when the car is parked and off.
If anybody else has any REAL technical details, I'd love to hear them. In particular on the inverter ratings... Thx!
eggehad is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 10:38 AM
Help with charging system blkdmnrcing General Discussion 2 01-24-2006 08:41 PM
Supra Hybrid - 300 bhp nort0188 Toyota News 46 10-21-2004 12:13 PM
Charging System failing w/ new alternator TRDragoon Hardcore Tech and Competition 9 05-07-2003 12:42 PM
