oil changes - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Toyota Highlander Hybrid
Toyota Highlander Hybrid The first hybrid SUV from Toyota. The Highlander hybrid!
Old 08-07-2007, 11:30 AM   #1 (permalink)
View chicagoandy's Photo Gallery
oil changes
How often are people changing their oil?
I'm getting the nag' warning at 5000 miles on my 07. The color of the oil is like maple syrup - a bit darker than new oil but not by much.
My last Honda recomended oil changes every 10,000 miles.
I'm skeptical that I really need to be changing oil every 5000.
What do other people here do?
chicagoandy is offline   Reply With Quote
Old 08-08-2007, 12:54 AM   #2 (permalink)
View maclvr1's Photo Gallery
USA oil change
I was told every 5,000 miles to change it.
maclvr1 is offline   Reply With Quote
Old 08-08-2007, 10:17 AM   #3 (permalink)
View moneytrain8's Photo Gallery
USA
I have a Prius and a HiHy, and we just got the first HyHi oil change at 5k miles. Maybe you can wait longer, but I think we'll stick with that... although I'm sure some will cite some oil conspriacy and swear that you don't need to change it but every 40k miles. I have done the same for the Prius for the 50k miles I have driven it.
moneytrain8 is offline   Reply With Quote
Old 08-09-2007, 02:29 PM   #4 (permalink)
View Shipmate's Photo Gallery
If you don’t follow the minimum recommended oil change intervals, you may have to defend yourself if there is an otherwise warranty covered engine problem. That is, you may have the burden of proving that your failure to change the oil, as recommended, did not cause the problem. This would be very hard to do if it can be argued that the problem was at all lubrication related. You can, of course, change the oil more frequently without warranty coverage being an issue.
If you want to know how your oil is doing, you can have it analyzed. You take a sample, either at a change or from the crankcase via a tube put down the filler pipe, and send it to a laboratory which sends back a report. One lab that is well thought of is Blackstone-- www.blackstone-labs.com. This is what their web site introduction says: "Oil analysis can identify any problems developing in your engine long before they cause you an expensive headache. Or maybe you'd just like to get a good look at the microscopic wear your engine is producing. Can you run a fill of oil longer than 3000 miles? Are your oil and air filters doing a good job? We can answer these questions and more when you submit a sample of your engine oil for analysis" Their standard test is about $22.
My guess is that if you had reports showing that your oil was fine and did not need to be changed, you would have the proof needed to establish that not following the change interval was the cause of the engine problem.
I am new to the HiHy so I have no idea of how hard the ICE works, but it is high compression. I am thinking about using synthetic oil with the 5k change interval, the engine should be well protected and it may help with milage.
Shipmate is offline   Reply With Quote
Old 08-14-2007, 10:01 AM   #5 (permalink)
DeanP's Avatar
View DeanP's Photo Gallery
Every 5K as recommended.
DeanP is offline   Reply With Quote
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 10:01 PM
oh Snap! Oil Oil everywhere!! Shogun1011 Pre-88 Toyota Pickup/Hilux 9 07-09-2007 05:46 PM
Another oil change horror story! witxp 5th & 6th Generation (2002-2006 & 2007-2011) 16 05-13-2007 01:29 PM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
Help!! Oil Puddle Under Engine Structureboy Camry & Solara Lounge 12 01-17-2003 01:04 PM
