Pulsation at 40 mph TSB - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Toyota Highlander Hybrid
Toyota Highlander Hybrid The first hybrid SUV from Toyota. The Highlander hybrid!
Old 09-09-2007, 08:46 PM   #1 (permalink)
Hihy enthusiast
View Chevalde3's Photo Gallery
I saw on alldata web site that there is a TSB for the 2006 Hihy (2006 Toyota Truck 4wd hybrid) concerning drive pulsation at 40 mph. It is not on the 2007 Hihy list. After checking mine, it does in fact wobble a bit around 40 mph. Anybody else has this?
Anybody knows what has to be changed to circumvent this small problem (ECU reprogram?). Ill sure check this with the garage at the next maintenance inspection.
2006 Black Toyota Highlander Hybrid
Chevalde3 is offline   Reply With Quote
Old 09-30-2007, 12:01 PM   #2 (permalink)
Hihy enthusiast
Thumbs up
The ECU reprogramming did it. Works better now!
Old 08-03-2009, 04:23 PM   #3 (permalink)
View HGilmo's Photo Gallery
Problem at 40 mph
Our 2006 HH does the same thing at 40 mph. I'd love to try the ECU reprogramming - what is that? Also, what is a TSB or whatever it was that you referenced in your first post?
Thanks for any help you can give me!
HGilmo is offline   Reply With Quote
Old 08-03-2009, 05:45 PM   #4 (permalink)
Hihy enthusiast
Canada pulsation
ECU is one of the many car computers dedicated to engine management. Think of ECU reprogramming as a simple software update (like a computer) done by a Toyota Hybrid certified garage with a special analyser. They will do it (I had it done during a regular inspection) if you insist there was a Technical Service Bulletin about it. I do not recall the exact year 2006 TSB number. It is a less than a half hour job. Good Luck. By the way I still think it is a wonderful vehicule and am amazed at how the "car experts" still do not really understand it 4 years after its introduction.
Old 08-03-2009, 05:53 PM   #5 (permalink)
Thanks so much for all your help!
Old 02-10-2011, 11:14 PM   #6 (permalink)
Prangley's Avatar
View Prangley's Photo Gallery
Canada
Mine pulses and revs around the same speed. Will the ECU reprogram be covered by the power train warranty? I sure hope it works for me as well.
Prangley is offline   Reply With Quote
Old 02-14-2011, 09:40 PM   #7 (permalink)
Prangley's Avatar
ECU reset was covered by warranty, however, it did not solve the problem.
Old 03-14-2011, 05:51 PM   #8 (permalink)
View moroccokid's Photo Gallery
Chatter/pulsating acceleration on Highlander Hybrid
06 Highlander Hybrid with a similar problem. they applied a TSB to reprogram the PCM but problem got worse. Now it does this at all speeds.
moroccokid is offline   Reply With Quote
TSB EG046-06--Ever hear of it?? rikbee 2nd Generation (2005+) 3 06-19-2007 10:24 PM
Retrofitting Other Car Model Wheels With Gen3 (5x114.3) A2brb 3rd & 4th Generation (1992–1996 & 1997–2001) 13 11-11-2005 10:55 PM
New IS and GS450H silver04rollas Toyota News 65 04-16-2005 12:18 PM
Tire suggestions? Vaipunk Archived Corolla threads 11 03-11-2005 07:48 AM
deciding on a car toyota vs mazda koss78a Archived Corolla threads 104 10-20-2004 01:15 PM
