How do you calibrate? - Toyota Nation Forum : Toyota Car and Truck Forums
Toyota Highlander Hybrid The first hybrid SUV from Toyota. The Highlander hybrid!
#1 Old 11-05-2009, 12:39 PM
06 Highlander Hybrid
Quoted: 0 Post(s)
(Thread Starter)
I've seen several references to calibration after a dead battery. One referred to a "how to" in this forum and another talked about the performance mode.
I've searched for "calibrate" and "calibration" but haven't found a procedure.
Can anyone tell me where I can find it?
Thanks in advance,
Howard
Howard_Woodard is offline
#2 Old 11-05-2009, 03:35 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 162 Post(s)
When you ask about recalibrating, what are you referring to? Nav system? Main ECU?
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now
#3 Old 11-05-2009, 04:12 PM
Quoted: 0 Post(s)
(Thread Starter)
I'm not sure but I'm guessing the ECU since it apparently effects performance and efficiency -- or at least the calculation of efficiency. Here is the search link where I first ran across it. In particular, the 3rd thread down.
New (to me) '06 Highlander Hybrid Limited, 2 questions...
It refers to a calibration found elsewhere on the forum but I haven't been able to find anything. Apparently something that happens when the battery is completely dead. When we bought this car the dealership had it out front with an electronic sign on it and had forgotten to take it off and it drained the car's battery.
#4 Old 11-05-2009, 06:06 PM
Do you feel lucky?
TrailDust's Avatar
Quoted: 162 Post(s)
As I understand it the ECU will automatically "relearn" your shift points, etc., whenever power is lost and the battery reconnected. The driver doesn't need to do anything as the computer does it for you. Literature on this is extremely scarce, but a call to your local Toyota service center can probably provide additional information.
2002 Avalon XL
#5 Old 05-09-2010, 12:41 AM
Quoted: 0 Post(s)
The following systems need to be reset/recalibrated after the battery dies, drops too low or is disconected:
Compass in rearview mirror
idle speed control
Power windows
Sunroof
Sealt belt buzzer supression
JSTCD is offline
#6 Old 05-09-2010, 01:08 AM
THIS SPACE FOR RENT
humanoid's Avatar
Quoted: 26 Post(s)
The ECU will recalibrate on it's own after a couple tanks full of gas.
humanoid is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Toyota Highlander Hybrid
User Tag List
Linear Mode Linear Mode
