Highlander Hybrid gas filling problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Hybrid Forum > Toyota Highlander Hybrid
Toyota Highlander Hybrid The first hybrid SUV from Toyota. The Highlander hybrid!
Old 09-03-2005, 10:43 PM   #1 (permalink)
View H Ball's Photo Gallery
I have a new Highlander Hybrid and am unable to fill gas tank without nozzle clicking off thirty or more times. Doesn't seem to matter what angle or distance.
H Ball is offline   Reply With Quote
Old 11-21-2005, 04:33 PM   #2 (permalink)
View wheelwinner's Photo Gallery
Filling gas
Hi ... I used to have this problem with my '96 Camry and found that I had to pump the gas at the slowest setting (there are usually 3 I think). My HH does not have this problem but the same approach may help.
wheelwinner is offline   Reply With Quote
Old 11-21-2005, 04:33 PM   #3 (permalink)
Filling gas
Old 11-23-2005, 01:53 AM   #4 (permalink)
nodrogkam's Avatar
View nodrogkam's Photo Gallery
looks like you dont need more gas!
I would try other pumps and what not to see if it makes a difference. worse comes to worse take it back to the dealer. there shouldnt be any special way to fill it.
nodrogkam is offline   Reply With Quote
Old 11-28-2005, 11:04 AM   #5 (permalink)
View dubbedavalon's Photo Gallery
alot of the scions that toyota was selling had the same problem. Its like you have to move the gas nozzle around alot to get the pump to work. I think the scions had a recall on this gas pump problem. check with the dealer and see if there is any tsb's on the problem.
dubbedavalon is offline   Reply With Quote
Old 11-28-2005, 04:23 PM   #6 (permalink)
TMS Prius Expert
Tideland Prius's Avatar
View Tideland Prius's Photo Gallery
Try filling without the nozzle all the way in.
2010 Prius Technology Package (Cdn)
OEM Cargo Mat, OEM All-Weather Mat, LED ext/int lights, 5000K HID, OEM Fogs, Euro Mudguards
Tideland Prius is offline   Reply With Quote
Old 01-26-2008, 06:58 PM   #7 (permalink)
View Fodchuk's Photo Gallery
Im glad Im not the only one with this problem, I have a 98 camry and its annoying as hell, When you go to tell anyone about it they always say man just pull the nossel out a little etc ... and so on but its not the case. I even had my old man try it and he was puzzled also. Im hoping it nothing expensive but I figure next oil change ill get them to take a look at it unless someone has an answer before i do go...
Fodchuk is offline   Reply With Quote
Old 03-12-2008, 09:00 PM   #8 (permalink)
View Hybrid Driver's Photo Gallery
HH Gas Tank Problem
Here's hoping (for yr sake) it's just a fluke. But check my own forum entry ("Toyota Highlander Hybrid gas tank Problem") to compare: in my case, a previous filling (by gas station attendant) apparently overfilled the tank (by topping off) and caused some internal damage preventing gas from being pumped in after that. Problem cost me $1,700 to fix! (Am still trying to get Toyota to reimburse me under the warranty.)
Good luck!
Hybrid Driver is offline   Reply With Quote
Old 12-28-2011, 12:50 PM   #9 (permalink)
View jelefante3's Photo Gallery
Same problem - different solution
We have a 2006 Highlander Hybrid with the same filling issue, but I just happened to stumble onto a somewhat solution. If the gas pump you're using keeps clicking off, then just turn the power on in the car to the accessories setting (not all the way on - don't start the car) and this seems to prime your gas line and the clicking issue goes away for this fill up.
jelefante3 is offline   Reply With Quote
Old 12-28-2011, 09:33 PM   #10 (permalink)
View dfigu's Photo Gallery
I've also had this problem in my Acura TL. It does not always happen, it may just be the sensitivity of the pump. I have not yet re-filled my HHY...
dfigu is offline   Reply With Quote
