Hi superjeer,
Yep.
As for price, it all depends. $600-800 is toward the low end for carbon fiber (CF) hoods. A 100% CF hood using the best possible materials (meaning the lightest and strongest with the best engineering) would easily cost more than $2000. But that is out of most people's budgets, including mine.
Instead, quite a few manufacturers produce carbon-fiber "reinforced" fiberglass hoods. That means that only the top couple of layers (if you're lucky) are CF. The rest is fiberglass. It's more for looks than for performance.
Those range in price from $300-1200 or so. I have found that the really cheap hoods seem to be in the $300-500 range and are usually poor quality. I've had shrinkage, cracking, warping and a host of other issues. These manufacturers usually put one layer of CF (hundredths of an inch thick) over a poorly done fiberglass hood. Garbage in- garbage out.
My advice to anyone into the whole CF thing...if you want looks go mid-range. If you want looks and performance, save up and go top-of-the-line. And if you like throwing money out the window, buy the bargain crap. Remember, body parts are under constant stress...temperature changes, air pressure, weather, twisting, flexing, and so forth.
I was debating putting together a group buy for these CF hoods for the Scion XB to see if I could negotiate a better price, but there'd have to be enough interest. Time will tell.
In the meantime, I'm going to focus on a new set of flares for my 4x4.
