need help: vsc, trac off, check engine light ON - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xB Forum > xB Lounge
xB Lounge General discussion area for all generations of the Scion xB.
Old 08-26-2005, 03:04 PM   #1 (permalink)
View chexmixb's Photo Gallery
hi... My vsc, trac off and check engine light came on again... The mods I did was drop, rims and injen sr intake... I cleaned the maf sensor with electronic cleaner... That did not help...sometimes I smell gasoline by the gas cap... I take out the cap and put it back in... That did not help... then i did the obdII scanner...and got 3 codes...
1. P0441 evaporative emission control system incorrect purge flow
2. P0442 evaporative emission control system leak detected (small leak)
3. P0446 evaporative emission control system vent control circuit malfunction
Not sure what's that... But if anyone know please help... Thanks
chexmixb is offline   Reply With Quote
Old 08-27-2005, 01:28 PM   #2 (permalink)
Old Fart
View Paper's Photo Gallery
The last time I had those codes with a Toyota, it was my fault.. I filled the fuel tank, and then topped off a couple times.. Then I parked the vehicle in the hot sun for a couple days after only driving a couple miles.
What happened was the fuel expanded into the charcoal canister and filled it.. Auto Zone checked the codes and reset it for me, and lucky for me, the guy who checked it had seen it before and told me to quit trying to pump gas in after the nozzle clicks..
That was 2 years ago and I've never had a problem, since. I also quit trying to force more gas in the tank..
My guess is, you're still under warranty?? Why not let the dealer take a look?
Waitin' for my box..
Paper is offline   Reply With Quote
Old 08-27-2005, 02:07 PM   #3 (permalink)
Reppin my Home
troy's Avatar
View troy's Photo Gallery
Just so you know, the trac off and VSC light are sensors that are tied into the CEL light sensor, they generally go off when the CEL light goes off.
troy is offline   Reply With Quote
Old 10-10-2005, 12:06 AM   #4 (permalink)
View ybike2's Photo Gallery
I've been struggling with this same issue. In fact, my 02 Sequoia stalled three times today. I found this site - http://www.findarticles.com/p/articles/mi_qa3828/is_200207/ai_n9092642 - added brake fluid to the master cylinder and problem is gone... Go figure!!!
ybike2 is offline   Reply With Quote
Old 10-24-2005, 11:01 PM   #5 (permalink)
Dacatz's Avatar
View Dacatz's Photo Gallery
did u get this engine code after u fuel up the tank? if it is, try lock up the gas cap (with min. 3clicks after u tight the cap) and reset the code and it should be fine..... basically this engine code is emission issue....i know for the 98 to 2002 corolla and camry v6 they have a solenoid called VSV or tank VSV near the charcoal cansister always malfunction....try it first see if the gas cap tight first, otherwise u have to send your car back to the dealer to check if the vsv solenoid is okie or not....
ybike2: for your truck is different....since u have low brake fluid, which cause less fluid pressure to control your truck VSC system also your truck have EBD electronic brake thing...that's why it cause it stall....and cel light on.....one more thing, u truck have a special way to bleed the brake.....in which u have to go back to the dealer to do it....becoz of the VSC system....if u don't bring it back to dealer to do it, u might get the cel light again!
Current
92 Previa rwd (Captain seat, dual roof, cool box)95 Previa s/c rwd (Captain seat, dual roof)
Sold
93 Previa rwd Captain seat (parents took it),92 Previa (base model),92 Previa rwd (Captain seat, dual roof),91 Previa rwd (rip),98 240sx rwd,91 Corolla wagon fwd,86 Ae86 rwd
Dacatz is offline   Reply With Quote
Old 11-06-2005, 01:39 AM   #6 (permalink)
Toyota bB "Tribute"
jethro b's Avatar
View jethro b's Photo Gallery
Filling the fuel past the click is a big NO NO on the xB. Hopfully they will fix it under warranty. It is an expensive fix if not. Good Luck Bro!
05' Scion xB Classic in BCP Scikotics/Nashville Chapter
If You Don't Drive a Box... Why Bother?
xB= toaster or box
xB2= neither
jethro b is offline   Reply With Quote
Old 01-14-2006, 08:01 PM   #7 (permalink)
View Undrstm8ed's Photo Gallery
What up Jethro?!?!?!
funny find you every where...lol
Undrstm8ed is offline   Reply With Quote
Old 02-09-2006, 07:30 PM   #8 (permalink)
View rtrimyer's Photo Gallery
Didn't tighten up my gas tank cap all the way and my did the same thing. Reset at the dealer and its good.
rtrimyer is offline   Reply With Quote
Old 02-09-2006, 08:32 PM   #9 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Your under warranty.
Go to the dealer instead of trying to fix it yourself.
Nad1370 is offline   Reply With Quote
Old 04-02-2006, 10:11 AM   #10 (permalink)
View trevor.pcgeek@g's Photo Gallery
I just had the same symptom, but it is the symptom of many different problems it seems. They had to replace several parts related to my timing to fix it up. I had to take it in 3 times before it was completely fixed.
trevor.pcgeek@g is offline   Reply With Quote
Old 04-03-2006, 03:52 PM   #11 (permalink)
View imemikey's Photo Gallery
I had the same problem when I installed my intake, I disconnected my battery for about 15 and let everything reset.
imemikey is offline   Reply With Quote
Old 02-21-2009, 12:24 AM   #12 (permalink)
Joined the dark side. :D
Gameroom cash: $579891
View workerant's Photo Gallery
After using the car for over 50K miles and this problem starting to appear. I'll try these easy solutions see if it works. Thanks guys.
Else dealer for me.
workerant is online now   Reply With Quote
Old 05-04-2010, 12:45 PM   #13 (permalink)
View Fred_2726's Photo Gallery
I just had this same problem this morning driving to work. Same codes pulled at Autozone. Just wondering if anyone has any more updated information.
Autozone seems to think its a faulty gas cap. Any thoughts?
Thanks in advance,
Fred
Fred_2726 is offline   Reply With Quote
Old 02-19-2011, 02:21 PM   #14 (permalink)
View PeteNuclear's Photo Gallery
Warranty for VSC
My camry has 90k + and 9 years old. When does the warranty for correcting VSC/ Trac Off expire?
Thanks
Pete
PeteNuclear is offline   Reply With Quote
Old 02-21-2011, 02:39 PM   #15 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
A while back for your car my friend. at BEST..5yrs 60k miles.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
