need help: intake related? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xB Forum > xB Lounge
xB Lounge General discussion area for all generations of the Scion xB.
Old 09-01-2005, 12:56 AM   #1 (permalink)
View chexmixb's Photo Gallery
Ok I installed an injen short ram intake couple months ago... it was working fine... Now when im in a complete stop... About 30 seconds later feel like the engine is choking... Meanin feel like air not goin into the engine,I hear th hissing noise goin on and off, the rpm almost reach to 0 then back to almost 1...then when I putem back to neutral then to drive its ok... Then later it happen again... Not as worst though... I reinstall the intake again... Still the same situation... Yesterday I changed the intake to stock... I already died out once... And when I was driving home... It felt like it was choking... Anys suggestion? Thanks
chexmixb is offline   Reply With Quote
Old 09-01-2005, 08:14 AM   #2 (permalink)
View dexter_5000's Photo Gallery
is the air filter cleanable if so i'd try cleaning it
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 09-01-2005, 08:30 AM   #3 (permalink)
Official Saipan Member
rogerman's Avatar
View rogerman's Photo Gallery
maybe theres a leak
1992 Hilux 4X4 22R-E Manual, LCE Headers, Epn cam, super 40, and revirginized.
rogerman is offline   Reply With Quote
Old 09-01-2005, 12:18 PM   #4 (permalink)
How do you check if there's a leak on the vacumme tubes?The filter can be cleaned... But I installed the stock intake so I can eliminate the intake problem if the vsc, trac off and check engine light come on... Thanks
Old 09-06-2005, 04:29 PM   #5 (permalink)
Well went to the dealer and they said that the gas cap wasn't on good... And they suggested that when fillin up gas... Don't top it off... So hopefully thas been fixed... Thanks for the help
Old 09-16-2005, 11:34 PM   #6 (permalink)
View joe52985's Photo Gallery
I have the injen intake for the xB. Did your intake come with a little filter you had to cut that large vaccum hose in half and place on there? The older injen intakes didnt, and filter oil and debris from the pipe screwed up the maf sensor, if you dont, call injen and they should send you one, put your stock intake on and take it to the dealer, if its the maf, it will be replaced under warranty.
by the way, my first post, hello all!, i have an 04 polar white xb-5 spd of course lol
joe52985 is offline   Reply With Quote
Old 09-30-2005, 12:13 PM   #7 (permalink)
I don't think its the intake... Cause when I had the stock intake the lights came on.... I check with the obdII scanner... Got
1. P0441 evaporative emission control system incorrect purge flow
2. P0442 evaporative emission control system leak detected (small leak)
3. P0446 evaporative emission control system vent control circuit malfunction
I replaced the gas cap with a locking gas cap... Still light come on... Then I pull the efi fuse then back in to reset it... The after 40 miles or so... Lights come on... Any more suggestion? Thanks
Old 09-30-2005, 12:14 PM   #8 (permalink)
I don't think its the intake... Cause when I had the stock intake the lights came on....I also got the small filter... I check with the obdII scanner... Got
