Code P0012, anyone dealt with this??? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xA Forum
xA Forum Discussion area specifically for the Scion xA (NCP61)
Old 07-12-2007, 09:01 PM   #1 (permalink)
View db131994's Photo Gallery
The info AutoZone gave me on probable causes is a laundry list, so before I start hanging new parts I'm hopeing someone has had this... It runs fine, seems to idle a tic rough, but that could be my imagination... It has come on for about 2 days, went off for a few weeks, then returned yesterday. Appreciate the help! 2005 XA
db131994 is offline   Reply With Quote
Old 07-12-2007, 09:26 PM   #2 (permalink)
I am HOT? NO SHIT?
View Driver's Photo Gallery
Did they tell you what that code means? I don't know ( or have the OBDII scantool with me or a xa) what it means.
Driver is offline   Reply With Quote
Old 07-13-2007, 10:02 AM   #3 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
Never heard of that code before.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 07-13-2007, 10:34 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
P0012 Camshaft Position "A" Timing Over-Retarded (Bank1)
That could cause a rough idle. Would also have a lack of preformance/power too though. I would clear that out and see if it comes back. Some of the possible causes are dilluted oil or a problem in the PCV (OCV) system. I would see if the code returns before changing anything.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 07-14-2007, 10:22 PM   #5 (permalink)
View Mark G's Photo Gallery
I've had the P0012 three times on my '04 MR2 Spyder (1ZZ stock engine). I've cleared it each time, but it has come back after about 1 week of driving. Engine is running great. No noise. No oil consumption. No loss of power. No odors or exhaust smoke. I'm confused.
Mark G is offline   Reply With Quote
Old 01-10-2008, 01:54 PM   #6 (permalink)
the xb guy
View hemi2l's Photo Gallery
sounds like your have a problem with your camshaft timing oil control valve sticking or stuck in the open position replace it and the code should not come back ps i have 18 of these in my fleet with 300,000 miles or more so i have seen this before
hemi2l is offline   Reply With Quote
Old 02-15-2011, 12:29 PM   #7 (permalink)
View derjuden's Photo Gallery
I have a 2005 Xa scion with just under 100k. Its a manual and when looking up this code that came up on my car a few weeks ago I found this. http://tijil.org/Scion_TSBs/eg00307.pdf My VIN falls under this so I'm going to check with a dealer to see if there is away to see if this was done on the car already. I had the code cleared but it came back and now the car on accel. stutters and hesitates for a bit then clears in about any gear but 5th. Runs fine on the hwy its just city driving you really notice it.
I bought this car used from a dealer so I don't know how old the fuel filter, plugs, cap/rotor or plugs are. I'm going to find out today, but would those things cause this error code (P0012) http://engine-codes.com/p0012_scion.html ?
derjuden is offline   Reply With Quote
Old 03-10-2011, 04:12 AM   #8 (permalink)
Turbos = Witchcraft
Ne0z31's Avatar
View Ne0z31's Photo Gallery
This is exactly what the issue is, I just fixed it on my car and it ran me ~$600.
Of course naturally as soon as I fixed it my headgasket decided to go on me :P
Ne0z31 is offline   Reply With Quote
Old 03-10-2011, 04:32 PM   #9 (permalink)
So the story on mine gets better. I took it to the local Toyota dealer and got a call from them that the camshaft gear has to be replaced. That is covered under my warranty, but what isn't that I'm super pissed about. Is that when the other dealer I bought it from was cleaning the engine bay, they used a pressure washer and got water in the coils and damaged the spark plugs. They are picking up that bill and the dealer says this isn't the first time they have seen this.
Toyota Engine code vivian General Discussion 22 12-27-2008 02:16 AM
PO420 Catalyst code on '02 corolla digger89 Archived Corolla threads 1 09-19-2006 01:38 AM
ABS light on, code 36, 71 bronzemaxell 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-20-2006 11:28 AM
reset ecu and code for activating the radio sw0rdf1sh Camry & Solara Lounge 3 06-26-2006 11:21 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 07:36 PM
