XA ac problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xA Forum
xA Forum Discussion area specifically for the Scion xA (NCP61)
Old 08-13-2007, 05:32 PM   #1 (permalink)
View bconman's Photo Gallery
XA ac problem
I have a 2006 and the ac either works, or does not work. I can drive to store and it will not kick in, but on way home it may work like a champ. This is driving me nuts. Any ideas of what I should be looking for? AC lite will be on but no ac. HELP. Got to be something simple. I sure would like it to work all the time! Thanks guys.
bconman is offline   Reply With Quote
Old 08-14-2007, 08:19 AM   #2 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
How many miles on your xA? It's not still under warranty is it?
It could be any number of things ranging from a bad relay to a failing compressor.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 08-14-2007, 03:58 PM   #3 (permalink)
Out of warranty. When it works, it works fine. Seems the hotter it is the less likely it is to come on. I checked all fuses and connections. It may work 4 or 5 times in a row and also after it works, I can turn it off and back on as many times as I want and it will work. Only seems to balk after a new engine start, so I may hop in car and drive to store and blow warm air, but on the way home it may start up. How do I check relay? Dealer is 70 miles away so that makes it hard to find time to get it checked. I know its something simple. (I hope)
Old 08-15-2007, 09:50 PM   #4 (permalink)
Hmmm. Coming home from work today it would not come on so I kept pushing the ac button on and off several times with no luck, then I turned the fan to off and then back on and the ac kicked in. Just trying to narrow down what the problem could be. Still wondering if it is sticking relay problem.
Charcoal Canister Problem on 2006 Xa..Help! kansascion xA Forum 6 10-16-2009 10:54 AM
SCION xA Chronology BLUEMEANIE xA Forum 0 02-09-2007 01:45 PM
Radio Problem on New XA mariegn xA Forum 4 02-04-2007 05:39 AM
AC system shot? Any advice? joneswak Archived Corolla threads 6 12-27-2006 02:19 PM
Radio Problem on New XA mariegn xA Forum 7 03-08-2006 03:42 PM
