oil level - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xA Forum
xA Forum Discussion area specifically for the Scion xA (NCP61)
Old 08-23-2007, 02:35 PM   #1 (permalink)
netfish's Avatar
View netfish's Photo Gallery
oil level
I changed my oil about 1 month ago. today I decided to check the level. Level is higer about an inch over the "F" mark. IS it normal ? I checked the manual and it sas that oil level has to be between "L" and "F" marks. If it will be higher then F it might damage engine.
I need advise : what should I do?
netfish is offline   Reply With Quote
Old 08-23-2007, 05:48 PM   #2 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
an inch over the fill mark is a little much but you likely wont have any issues. Do you remember how much oil you put in your engine?
I'd say drain and refill the oil just to be safe. I'ev seen a few engines running with twice the amount of oil in them that they should have. They didn't blow but they weren't happy.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is online now   Reply With Quote
Old 08-23-2007, 07:36 PM   #3 (permalink)
netfish's Avatar
I did oil change in TOYOTA dealership. .... they probably should know.. ...... May I have vibration of the engine because of that ?
Old 08-24-2007, 10:27 AM   #4 (permalink)
HATEnFATE's Avatar
I'd take it up with the dealer. let them know what happened.
Jason Johnston
(800)342-7045
Old 08-24-2007, 10:31 AM   #5 (permalink)
View dexter_5000's Photo Gallery
did you check the oil cold or hot? it gets sloshed around easily after the engine been running. will give you an inaccurate reading.
5EFHE Powered JDM Engine
dead 8/23/2005
september 7, 2005 got my new 06 Scion XA
dexter_5000 is offline   Reply With Quote
Old 08-24-2007, 01:15 PM   #6 (permalink)
netfish's Avatar
I check oil level when engine was cold. And i checked it abouty 3 different days
Old 08-24-2007, 01:36 PM   #7 (permalink)
HATEnFATE's Avatar
It wont bo that major of a difference hot or cold but you want to make sure that the engine is off unlike an Auto tranmission where the engine needs to be running and up to operating temp.
Jason Johnston
(800)342-7045
Old 08-24-2007, 04:53 PM   #8 (permalink)
netfish's Avatar
engine is off. I checked the level before going to work.
2007 Camry Oil Change FYI! Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 139 11-05-2011 08:36 PM
WTF! 2007 Camry SE Only Giving Me 263.7 mi WITH Full Tank! LunarMist 5th & 6th Generation (2002-2006 & 2007-2011) 262 01-15-2011 02:17 PM
v6 Oil Level Warning For All Toysrme Camry & Solara Lounge 2 10-03-2006 11:53 AM
02 Tacoma 3.4L Oil Level and Coolant Level usmcjsy 1st Generation (1995.5–2004) 13 09-08-2006 09:28 PM
Oil Changes for Dummies Peter Off Topic 20 01-04-2006 05:32 AM
