GRIND when AC turns on/off, Fan doesn't come on when ac is off...? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > xA Forum
xA Forum Discussion area specifically for the Scion xA (NCP61)
Old 10-26-2007, 01:57 PM   #1 (permalink)
synthbent715's Avatar
View synthbent715's Photo Gallery
Anybody have an idea of what my problem is?
When I turn my AC on I hear a grind noise from my engine bay, when the fan kicks in when my AC is ON it grinds again, when the fan turns off and my AC is ON, grinds again, when I turn my AC OFF, it grinds... however...
When my AC is NOT ON, I hear NO grinding noises and I stood there for 45 minutes with my engine running idle and the fan never came on, is that normal?
It seems the grind sound is attatched to the AC, its just strange that it makes the grinding noise as the fan cuts on and off while my AC is running.
I've actually got an apt for the dealership tommorow, another dealer said they fixed the noise by cleaning the ac blower, but that never stopped the grinding noise.
I just want to be sure they finally fix it, going into it with the most knowledge about it myself would help I guess.
Thanks everyone.
synthbent715 is offline   Reply With Quote
Old 10-27-2007, 12:45 AM   #2 (permalink)
wonger's Avatar
View wonger's Photo Gallery
need a new a/c compressor..
you really need new clutch on the compressor but if it is still under warranty most likely they replace the compressor..
08 Honda CBR600RR
06 Honda S2000
94 Honda Accord
97 Lexus SC400
wonger is offline   Reply With Quote
Old 10-27-2007, 08:36 AM   #3 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
It might be the fan, compressor or a bad valve in the system. My Spec-V does the same thing. Has since day one.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 10-27-2007, 03:07 PM   #4 (permalink)
Well I just called the dealer, they said the water pump is "pouring" and they have to keep my car till tuesday.
They said they're gonna give me a loaner if I get up there before 6pm.
If my water pump was pouring wouldn't I be losing coolant? I've never noticed one coolant leak and my coolant level is always fine, strange...
Old 10-27-2007, 04:58 PM   #5 (permalink)
Looks like it'll be in the shop till tuesday.
I got a Corolla S loaner, sweet!
Old 10-28-2007, 01:53 PM   #6 (permalink)
wonger's Avatar
they might say it was pouring but most like it was leaking very little but when it leaks out .. the toyota coolant gets hard and chunky.. sticks to the engine block.. pink in color.. i seen this before on the older xB . if u look on the pass side engine.. you might be able to see alot of dried up pink coolant..
08 Honda CBR600RR
06 Honda S2000
94 Honda Accord
97 Lexus SC400
Old 10-28-2007, 03:33 PM   #7 (permalink)
I have noticed little white-pinkish dots all over my engine bay, I wondered if they were coolant but whenever I check the level its always fine, I guess it is leaking then, good thing they cought it, seeing as the dealership I bought it from failed to catch it 3 times in a row, and this new dealership found it right away.
My Electric Fan Mod is Complete! Pb 2nd Generation (2005+) 116 08-14-2009 12:34 AM
1993 Hydraulic Fan Motor... RodMillenFan 3rd & 4th Generation (1992–1996 & 1997–2001) 5 06-10-2008 10:56 AM
AC blower fan resistor values Gopal 1st & 2nd Generation (1983–1986 & 1987-1991) 13 08-08-2007 08:20 AM
radiator and ac fan not spinning rizzo Camry & Solara Lounge 6 05-11-2004 03:02 PM
AC Compressor and Drier removed, now radiator fan stays on undrcroft Camry & Solara Lounge 0 08-07-2003 07:11 PM
