Love the Tc....hate the clutch - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > tC Forum > 1st Generation (2005-2010)
1st Generation (2005-2010) Discussion area specifically for the first generation Scion tC (ANT10)
Old 10-06-2006, 09:58 PM   #1 (permalink)
View dave121221's Photo Gallery
When I test drove the Tc, I drove one that had automatic as there wasn't a straight stick on the lot. But I ordered a manual shift. Considering how sophisticated all the controls are on the Tc, I can't understand how they could screw up the clutch which has been around almost as long as automobiles have. This is the most unconfortable clutch I have encountered in over sixty years of driving. When you press it with the ball of your foot, your toes are pushed backwards from the firewall! If you try to compensate by lowering your foot on the pedal, your heel catches on the edge of the floor mat! And I wear only a size 9 shoe! I can't imagine what it must be like for a guy with a size 12!
I'm considering attaching a block about an inch thick or more to the pedal to see if that helps. I regret that I didn't test drive a manual before I bought, else I would probably have shopped around more. As I said, I love the car but the clutch is annoying and begs better positioning in relation to floor and firewall.
dave121221 is offline   Reply With Quote
Old 10-07-2006, 06:08 PM   #2 (permalink)
Toyota Parts since 1981
Gameroom cash: $146955
View DOHCammer's Photo Gallery
I test drove a stick Tc before I bought my Camry and found the same problem as you. Since I have a size 13 EEE, I also found the gas and brake pedal too close together and very hard to navigate. My Camry has properly spaced pedals and an easy to modulate clutch. Much better setup IMO.
07 Camry SE V6
TRD Dual Exhaust & Air Filter
05 Highlander V6 AWD
170K miles young
DOHCammer is offline   Reply With Quote
Old 10-09-2006, 02:03 PM   #3 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
I could agree with you. the one solution that I've heard is some of the guys I know have put in clutch stops to help alieviate the problem. The stop prevents your foot from going all the way to the floor. It goes as far as it needs to get the plate away from the disc. Supposed to help with drag racing too.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Urgent; hi performance clutch question sloppybeak General Discussion 0 03-27-2006 09:24 PM
Soft Clutch + Can't shift into / out of gear !! noobiedoobiedo Camry & Solara Lounge 6 03-20-2006 09:21 AM
Test-Drive: 2005 Scion tC w/ 5-speed manual kman10587 1st Generation (2005-2010) 4 07-29-2004 10:46 PM
My review on Spec Racing Stage II kevlar clutch kit for 1nz Wraith Yaris, Vitz and Echo Forum 0 04-13-2004 10:34 PM
I Hate Bitches Reit38 Off Topic 33 07-23-2003 07:18 PM
