06 TC can't get HID worked on it.. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > tC Forum > 1st Generation (2005-2010)
1st Generation (2005-2010) Discussion area specifically for the first generation Scion tC (ANT10)
Old 03-04-2009, 02:28 AM   #1 (permalink)
View umohodou's Photo Gallery
i just bought a set of 9006 6000K HID conversion kit for my 06 tc...i saw a tag on the kit showing that it is a 35W (light bulb ?or ballast?
They never light up on the tc...but they do on a 2000 honda accord...(that means the kit is in good condition,,,but they just dont work on a tc)
anyone has any clue to it?? just brainstorm, shout out what you think...
how can i solve it?
thanks for answering!
PS i tested them after i went to a toyota service dealer...i will hand it to the dealer again as long as i can get some ideas here...thanks
bought from http://cgi.ebay.com/ebaymotors/ws/eB...2342&viewitem==
umohodou is offline   Reply With Quote
Old 03-04-2009, 05:08 AM   #2 (permalink)
View DaiFai's Photo Gallery
you might need to remove the 2 pins from the headlight bulb connector and switch them around. Just double check which wire is positive on your Accord and compare it to your Tc.
DaiFai is offline   Reply With Quote
Old 03-04-2009, 05:37 PM   #3 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
Does your kit have wires going directly to the battery or do the ballasts feed directly off of the headlamp wire harness?
I'm blocked from ebay here at work so I couldn't see if it did or didn't have the battery wire.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 03-04-2009, 05:51 PM   #4 (permalink)
you can visit
www.XenonHIDworlds.com
because the ebay seller is this site.
you can see pictures on this site.
thanks for the answers so far.
Old 03-05-2009, 11:20 AM   #5 (permalink)
UTaco's Avatar
View UTaco's Photo Gallery
Have you checked your grounds when you ground them on your tC?
To answer HATEnFATE's question, it doesn't look like they are wired directly to the battery.
08 Taco DC LB 4x4 sport
Scion fogs 4 sale Taco stuff for sale, entire truck is for sale actually
http://www.toyotanation.com/forum/sh...d.php?t=361926
http://www.toyotanation.com/forum/sh...&postcount=519
UTaco is offline   Reply With Quote
Old 03-05-2009, 01:41 PM   #6 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Toyota's usually have a switched ground instead of a switched power. So what works on a Honda might not on a Toyota. I'll dig around for the wiring diagram I drew up for my Toyota/Denso setup.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 03-05-2009, 01:58 PM   #7 (permalink)
What are the grounds???
if the voltage is not sufficient for the ballast, how can I make it sufficient?
Old 03-06-2009, 04:46 AM   #8 (permalink)
Canada
HATEnFATE's question is. Does your HID kit comes with a relay wiring kit. If you have a relay wiring kit, it should just work when you plug everything in. I'm thinking you don't have this relay kit and what you need to do is remove the pins from the 2 headlight connector and re-arrange them to the other slot, that's how toyota's headlights are wired. If you have a volt meter or a test light, you can see which wire is positive. The Toyota's ground on your headlight should be white & black wire.
Old 03-07-2009, 09:43 PM   #9 (permalink)
i dont think i have the relay wiring, coz the seller is asking me to buy a RELAY HARNESS.
I am not sure if switching the 2 pins will work..
I tried them on my fd's tc, they don't work either....
anyone has no problem with installing HID kit please tell me where you bought them...I bought from xenonhidworlds.com...i just want to get HID asap! thanks!
Old 03-09-2009, 07:48 AM   #10 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Slow down and take your time. Rushing thru this is a good way to fry your headlight harness and possibly some other things.
Did you try switching the pins?
I think your first problem is that the ebay auction says the kit is for "SCION XA XB XD TC 9003 H4". The xA and xB and I think the xD all run 9003 H4 dual filament but not the tC. The tC has separate 9005/9006 single filament bulbs. You need to determine if the kit is correct for your car.
Let me know and I will try to help. If you cannot tell what base type your kit has, pictures of the actual kit will help immensely ... at this point I just need to see the bulbs.
If the kit is the correct one for your car you will need to post pics of the entire kit showing all leads as the pic the seller has on his ebay auction is for a plug n' play kit.
btw, please do not double post this topic. Thanks.
Old 03-09-2009, 06:09 PM   #11 (permalink)
http://s711.photobucket.com/albums/ww119/umohodou/HID/
photos are uploaded...
i dont think i can switch the pins around coz they look like they are attached quite tightly...
Old 03-09-2009, 06:11 PM   #12 (permalink)
thanks
Old 03-10-2009, 02:35 PM   #13 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
That is the correct kit for the tC.
hmm...
Under the black cap in this photo - LINK - is there a fuse? If so check both ballasts, make sure they're not blown.
Also try pushing the pins in this pic - LINK - a little closer together so they make definite contact to the female end on the car. And maybe try using a little electrically conductive grease on them.
Let me know if any of that that works.
Old 03-13-2009, 04:21 AM   #14 (permalink)
they both work
pushing pins wont work
i have ordered a batter relay harness..i will put them on my car..and hopefully they work!
thanks!
Old 03-13-2009, 10:23 AM   #15 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Let us know what happens.
