intake - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > tC Forum > 1st Generation (2005-2010)
1st Generation (2005-2010) Discussion area specifically for the first generation Scion tC (ANT10)
Old 08-09-2009, 11:02 PM   #1 (permalink)
View rtm3's Photo Gallery
intake
i just put a intake on my engine light came on and it acts like i have turbo lag. could be the filter is to big and i know it could be my mase air flow .
rtm3 is offline   Reply With Quote
Old 08-10-2009, 09:21 AM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Disconnect the neg terminal on your battery and let it sit for about 10-15 min. Reconnect it and start the car. You should be good to go.
The lag you're feeling is the car going into 'limp mode' which is a programmed protective status the ecu uses when things like airflow dramatically change. The ecu just needs to be reset. Disconnecting the battery will do it.
btw, Welcome to TN!
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 08-18-2009, 08:32 AM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Originally Posted by rtm3 via PM
hey man i did what you said on the battery and it went off but it came back on. is their something im missing please help. im run a k&n short ram intake and their are no leaks that i can find also, should i buy a cheap exstintion peace.
How long did you leave it disconnected for? Try leaving it for about 30 min so you're sure the system is completely discharged. Rule of thumb is about 5min but I do 15. Usually I unhook it and just leave it off until I need to go somewhere.
You'll need to reset your sunroof and windows when you reset the ecu. Are you familiar with that process? ...if not, I can explain it.
If you are still getting the cel, you're going to need to replace the stock intake and take it to a dealership to have them look at it. Unfortunately the MAF sensor is very fragile in our cars ... its unusually fragile. I broke my first one. Had it replaced under warranty and have been fine since. I remove the new one every time I need to get to the SC's bypass valve and its been fine. I am extremely careful every time I have to touch it.
