Scion tC winter wheels - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Division and International Models Forums > Scion Forum > tC Forum > 1st Generation (2005-2010)
1st Generation (2005-2010) Discussion area specifically for the first generation Scion tC (ANT10)
Old 11-23-2004, 01:31 PM   #1 (permalink)
View wes2603's Photo Gallery
Question Scion tC winter wheels
I need some expert advise on tC wheels. I have a set of spare 16x6.5 wheels, 5x100 bolt patern with 55mm offset, I want to put on the tC for winter tires. The OEM wheel come with tC is 17x7, 5X100 bolt patern with 45mm offset. Diameter of the 16" tire can be adjusted so it will match the OEM 17" tire size, the thing I worry about is the wheel offset. I ran some calculation online, and below is the result:
The clearance from stut housing to the inside of the wheel will be 4mm LESS</FONT>
The outside edge of the wheel will RETRACT in towards the body by 16mm
Can someone tell me if the 16x6.5 wheels I want to use will rub against anything or cause any other problems?
Thx in advance!
wes2603 is offline   Reply With Quote
Old 11-23-2004, 02:37 PM   #2 (permalink)
Official Acura Troll
View 02RSX90camry's Photo Gallery
try posting on scionlife. i do'nt think many of teh people on here will know teh car in taht much detail. or you could try calling toyota, but they're dumb and will proabbyl tell you it won't work.
02RSX90camry is offline   Reply With Quote
