Engine Noise (sounds like exhaust leak) - Toyota Nation Forum : Toyota Car and Truck Forums
1st Generation (2000–2006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 10 Old 03-04-2008, 07:45 PM Thread Starter
Captain Underpants
project_tundra's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I have a 2002 Toyota Tundra Limited 4x4 and I have a phantom noise. You can hear the noise all the time but it is especially loud when the vehicle is cold. The noise speeds up its rhythmic ticking in the higher RPM's and sounds like air escaping so my first thought was an exhaust leak. I have replaced both manifolds with Toyota manifolds and the driver cat and this noise is still making an appearance. Anyone else have this problem and find a solution? The sound is definitely on the drivers side.
Kent
project_tundra is offline
post #2 of 10 Old 03-05-2008, 06:35 AM
Quoted: 0 Post(s)
exhaust leak
I had a 96 t100 that might have had the same thing. I found the y pipe exhaust sheild was cracked. sounds crazy but that was the sound i was hearing sounded like a exhaust leak.
02604fun is offline
post #3 of 10 Old 03-07-2008, 07:04 PM Thread Starter
Captain Underpants
Quoted: 0 Post(s)
(Thread Starter)
Just had it diagnosed furthur and it sounds like it might be injectors!
Kent
post #4 of 10 Old 04-09-2008, 03:40 PM
Quoted: 0 Post(s)
I have the 202 sequoia, and it's making the exact same noise. Did you ever found the root cause and got it fixed.
ts2002 is offline
post #5 of 10 Old 04-17-2008, 09:18 PM
SHIFTY23's Avatar
Quoted: 0 Post(s)
99 percent sure the exhaust manifolds are leaking. I work at a dealer and we do about 5 a year. not a cheap repair either. sorry I didn't read full message about you replacing manifolds. Another thing i have seen is piston slap when cold. very noticeable when cold on v8 engines and it is normal.
SHIFTY23 is offline
post #6 of 10 Old 04-21-2008, 11:01 AM
Quoted: 2 Post(s)
Piston slap seems to be a common issue in late model V-8's from Ford and GM as well. It may be due to the short-skirt, low-friction piston design compared to the old days. It annoys owners, but really does no harm. I only notice it for a very few minutes of initial warmup.
nikita is offline
post #7 of 10 Old 05-19-2008, 03:44 PM
Quoted: 0 Post(s)
I have an '03 4.7 with a similar noise. Really notice it accelerating from a dead stop or if accelerating from 55mph to pass someone. Definitely on the driver side. "Puttering" sound that increases in speed with increase in engine rpm. Seems like I've also lost the "smoothness" and power that the 4.7 normally had. No check engine light. Took it to my mechanic. No codes thrown. Replaced all plugs with NGK. Replaced fuel filter. visually checked exhaust system. "cleaned" injectors. Noise still there. Mechanic said might be a coil starting to go bad but no way to pinpoint which coil without a code. Expensive to replace all 8.
Any other ideas out there?
finfun is offline
post #8 of 10 Old 05-22-2008, 06:01 PM
bemrise's Avatar
Quoted: 0 Post(s)
I have an 08 Tacoma V6 and it makes the exact sound you guys are describing. The dealer keeps telling me its the injectors and its normal. Sounds like a manifold or cat problem.
bemrise is offline
post #9 of 10 Old 05-25-2008, 06:36 PM Thread Starter
Captain Underpants
Quoted: 0 Post(s)
(Thread Starter)
After hooking up some ears, it turns out to be an injector. I have been running some injector cleaner with Octane Boost in my fuel every other fill up and it doesnt seem to help!!! However I am getting 25 Canadian MPG on the highway with my truck so I also do not want to start replacing things to jynx it! The new ones are only getting 19-20!
Kent
post #10 of 10 Old 05-18-2011, 09:14 AM
Quoted: 0 Post(s)
Exhaust sounds inside cab problem
I realize this is an old thread but I was wondering if any of you tried to check the boot at the end of the steering column through the firewall... if this is cracked it will let all sorts of funny sounds come up inside the cab.
I too fought with this... changed my exhaust headers etc to no avail...
The simple $20.00 steering column gasket/boot fixed my nightmare.
All the best,
Garbal.
Garbal is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 1st Generation (2000–2006)
User Tag List
Linear Mode Linear Mode
« Back
