code po55 - Toyota Nation Forum : Toyota Car and Truck Forums
1st Generation (20002006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 2 Old 05-05-2012, 05:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
code po55
Hi folks : Went to advance a/p today. They said my oxygen sencor was bad in bank 2 sensor 1. Can anyone tell me where these locations are? Amd is their any special tools needed. 2000 tundra 4.7L 4x4. Thanks Bill
wdpcoinc is offline
post #2 of 2 Old 05-06-2012, 04:10 PM
Quoted: 0 Post(s)
http://www.toyotapart.com/Engine_Ban...SB-0398-09.pdf
B2S1 / Bank 2 Sensor 1 is on the passenger side exhaust manifold.
Sensor(s) 2 are downstream from the catalytic converter.
P0055 is a code for B1S3 which your truck does not have. P0052 is for the heater circuit on B2S1 -- this is probably what he meant, and it is common on your truck -- the heater will degrade over time.
http://www.obd-codes.com/trouble_codes/
Use only the Nippondenso sensor for your truck, and I recommend the dealer - you can order them in a 2 pack, do both sides and save some money; if the heater on Bank2 failed, then Bank1 is probably right behind it. Absolutely no Bosch, or other aftermarket sensors. Get the right sensors that fit and perform properly in your truck... plus Toyota has updated this part, so the new sensors should last longer. You wont save money doing it twice.
You're going to need a 7/8" Oxygen Sensor socket, some penetrating lube to remove, and some anti-seize for the install.
Good luck, and I hope this helps.
motorbreath777 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > 1st Generation (20002006)
User Tag List
Linear Mode Linear Mode
Back
