Interval for timing belt replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Tundra 1st Generation (2000–2006) Looking for dedicated discussion for the 1st Generation of the Toyota Tundra? This forum is the place for you.
post #1 of 6 Old 10-26-2008, 08:35 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello, I have a 2000 Tundra with 60k miles on it. I understand that the interval for replacing the timing belt is at 90k. The dealer indicated that since the truck is now 8 plus years old, that they suggest that the belt be replaced. Is this true or just the dealer trying to get additional un-necessary business.
Thanks for your help!
Gary Kodani is offline
post #2 of 6 Old 10-26-2008, 11:19 AM
just a nobody
Quoted: 118 Post(s)
Yes and No, sometimes it depends very much on how the truck is operated. If you are a easy going driver, and the type of driving you do are 50%/50% city and highway, then you can probably wait until 90k. However, having said that, the recommended maintenance schedule can be either follow by mileage or by time, so when you do your service depends on which route you take.
A little bit more info on the Toyota V8 or V6, both engine use a hydraulic tensioner for the timing belt, and unless you operate in a harsh environment that would cause the timing belt itself to deteriorate, it isn't unusual for the timing belt to last beyond the 90k recommendation.
N.E.O.
new echo owner is offline
post #3 of 6 Old 10-27-2008, 10:17 AM
Quoted: 2 Post(s)
I've found that changing parts arbitrarily at a certain mileage interval, like engine hours on aircraft, is not always best. It is better to inspect and replace parts "on condition". It does not take that much time to pull the plastic cover and look at the condition of the belt. Time may deteriorate parts as well as mileage, true, but that is why you need to look and feel.
nikita is offline
post #4 of 6 Old 01-12-2009, 07:05 PM
Quoted: 0 Post(s)
5 years or 90k miles, I have replaced them at 20k miles on a 01'
09camryUA is offline
post #5 of 6 Old 01-13-2009, 10:17 AM
Jumbo757's Avatar
Quoted: 0 Post(s)
how much you think im looking at for labor on replacing one of these? '03 tundra
Jumbo757 is offline
post #6 of 6 Old 01-22-2009, 06:41 PM
Quoted: 0 Post(s)
150, I have a spare new V-8 water pump i can include for 20 bucks... Thats my price i work at the dealer and would do it as a side job...
But we charge 5.5 hours for a V8 plus parts.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tundra Forum > Tundra 1st Generation (2000–2006)
User Tag List
Linear Mode Linear Mode
« Back
