2000 4Runner - Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
post #1 of 6 Old 01-09-2006, 08:11 AM Thread Starter
Chuck Norris rules
decoy562's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Hey guys,
My wife has a 2000 4Runner with the 3.4 V6 and 91k miles. Anyways, I replaced the radiator and put in a new battery a couple of days ago. The car then felt sluggish when taking off from a stop sign. After driving it a couple of days, it got much better, but today on the way in to work, the check engine light came on. I check all the fluids regularly, what else could it be? Is there a way to reset the engine light, or just have to take it to the dealer?
TIA
2006 Tacoma Double Cab - Indigo Ink Pearl, TRD Sport, Tow
2000 4Runner - Black, SR5, wife's car
decoy562 is offline
post #2 of 6 Old 01-11-2006, 07:18 AM
Quoted: 0 Post(s)
There are a million different reasons why the check engine light could be on... anything from the gas cap not being on tight to an O2 sensor going bad to lots of other things.
You'll need to hook up a code reader to find out exactly why it's on, then go from there.
Jackson
1996 4Runner
5" lift, 33" MTs, bumper, sliders... more to come
~ www.TrailAddict.com ~
jacksonpt is offline
post #3 of 6 Old 01-16-2006, 09:22 AM
Quoted: 0 Post(s)
I have a 2000 4runner with 95K and the same thing happened to me. The first time the check engine light came on, which was about 2 weeks ago, it was on for a short period of time and then it came on again on Friday, 1/13/06 and stayed on. My husband took it to Autozone this morning and they did a diagnostic and it came up with the Error Code of P0120, which is "Throttle/Petal Position Sensor/Switch A Circuit Malfunction" So, he is going to go by the Toyota dealership in town and just double check to see if that's what it is and then replace it. The part is approx. $80 at AutoZone.
Hope this helps. I had the same symptoms as your wife need as far as before the light came on. A little sluggish, etc.
Yodachic
yodachic is offline
post #4 of 6 Old 01-16-2006, 11:33 AM Thread Starter
Chuck Norris rules
decoy562's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Thanks for the help! I took it to autozone, and the code was P0171 (running too lean with the A/F mixture). I looked it up on this great site, then I replaced the air filter, PCV valve, and clean the MAF sensor. Good as new!
decoy562 is offline
post #5 of 6 Old 12-18-2006, 05:03 PM
Quoted: 0 Post(s)
Wink p0171
spray electrical contact cleaner on MAF sensor, reset cpu and your done.
fittipauli is offline
post #6 of 6 Old 11-25-2008, 09:00 AM
Quoted: 0 Post(s)
I saw your article in this forum though it's a few years back already I just wanted to ask if changing the trotle position sensor (po120) did the job for the check engine light showing up... I am experiencing the same situation and the diagnostics shows the same po120... thank you
hhhgame is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
User Tag List
Linear Mode Linear Mode
Back
