Trouble Code 171 / Where Do I Start Looking? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
Old 05-03-2006, 01:53 PM   #1 (permalink)
FWP
View FWP's Photo Gallery
My check engine light keeps coming on. The only code that keeps coming up is "0171 Bank 1 too lean"
What can cause this code and where do I look for a problem.
Thanks
Frank
FWP is offline   Reply With Quote
Old 07-13-2006, 04:22 PM   #2 (permalink)
View grizparker's Photo Gallery
Same problem...
I'm having the same problem and my local mechanic tried several different tests to try and find the problem, but with no luck. After he had my car for 3 weeks, he finally returned it with no fix.
In my case, it's a 4-Runner. It cranks fine, but the acceleration is horrible. Doesn't matter if it is between 10-20 or 70-80, it's very slow.
I'll keep checking back to see if anyone responded.
grizparker is offline   Reply With Quote
Old 07-16-2006, 05:18 PM   #3 (permalink)
00 4Runner 4x4, 06 Prius
dandeman's Avatar
Gameroom cash: $182822
View dandeman's Photo Gallery
You need to clean the Mass Air Flow Sensor as discussed here... http://www.4x4wire.com/toyota/4Runner/tech/OBDII_ECU/
As it becomes contaminated, it tends to under report the volume of air coming into the engine requiring the ECU to correct excessively to avoid running lean...
This link http://www.4x4wire.com/toyota/mainte...tenancep5.html goes directly to a procedure for cleaning the MAF, which ought to be done about every 30,000 miles..
dandeman is offline   Reply With Quote
Old 07-19-2006, 10:34 AM   #4 (permalink)
Thanks for the reply...I'll give it a shot.
Old 07-27-2006, 09:27 PM   #5 (permalink)
View medic2230's Photo Gallery
We took ours to the dealer a year ago and they replaced the mass air flow sensor and it was fixed. Expensive yes, but it shut the wife up even though I told her her that's what it was and I could order a replacement from dallas toyota and do it myself for less. Oh well...$260 for it but it only took them 45 minutes. Mine would have never gone to the dealer (tacoma). I got a great dealer here, you can go in there and ask them and they will tell you what the most likely thing that is causing the code. Her 4runner was a 99 with the 3.4 v-6. Cleaning may work also. The gas mileage went to hell when that code came up too.
Murph
medic2230 is offline   Reply With Quote
Old 08-10-2006, 09:05 PM   #6 (permalink)
View shipfitter88's Photo Gallery
Thanks
Frank
The code means a lean air/fuel mixture has been indicated by an abnormally rich correction factor.
Chris
shipfitter88 is offline   Reply With Quote
RAV4 intermittent start failure scottdac RAV4 Forum 5 02-25-2008 02:22 PM
Maxima problems..Won't start...Starter? TheMajesticking General Discussion 7 10-11-2005 06:02 AM
My '93 Camry LE wont start... Anyone know why? philosophy251 3rd & 4th Generation (1992–1996 & 1997–2001) 5 08-29-2005 08:39 AM
87 supra wont start iwannadie Supra Forum 13 08-09-2005 03:17 PM
1992 Cilica will not start Gil Celica Forum 6 05-19-2005 10:37 AM
