EFI fuse problem please help - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
post #1 of 7 Old 05-17-2006, 04:22 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy EFI fuse problem please help
I recently picked up a 1986 4runner for a great deal only problem is there is a fuel issue, to start off the 4runner was perfect running condition and then it was parked 1.5 years ago know it only is blowing the EFI fuse and won't start. I first checked my fuel pump and it didn't have any power (bad relay/fuse) so I ran a direct line to the pump to check it and sure enough I could hear it start up and pump fuel but still no start (since no fuse or relay) then I went a got a new relay since that sounded like the problem but still no fix, it is still just popping the EFI fuse, so I have a fuel pump that works when powered directly and a brand new EFI relay as well, but a damn blown EFI fuse that I can't get to work???? Please Please help I am hoping it is something real simple and easy
nick4runner is offline
post #2 of 7 Old 05-17-2006, 09:25 PM
Quoted: 0 Post(s)
ck the wires to fuel pump and injecters
rebult junk is offline
post #3 of 7 Old 05-22-2006, 05:17 PM
Quoted: 0 Post(s)
does the fuse blow when you key on, or crank or what?
if it blows when you first crank it, try unplugging things to see if it then doesn't blow, start with the distributor.
on some of the camrys a noise filter for the radio in the distributor shorts out and blows that fuse everytime you crank it.
deekay140 is offline
post #4 of 7 Old 05-30-2006, 05:49 AM
Quoted: 0 Post(s)
USA efi blown fuse
Ive seen distributor/ ignitor and even the coil wires cause efi fuse to blow on 2 different 89 22R E's keep it in mind. look for an old alarm relay too in one of the ignition circuits.
motoman366 is offline
post #5 of 7 Old 09-03-2007, 07:33 PM
Quoted: 0 Post(s)
Gen1 EFI fuse problem
Hi,
I got the similar problem with my 88 4Runner as Nick4runner's description. Mine starts up fine. The truck drives normally for about 5 min. and the EFI fuse blown of. I have noticed that whenever I give more gas (acceleracted), the fuse blows of sooner. The EFI is rated at 15 Amps. I usually installed a 30 Amps to limb home whenever that fuse blown.
I have checked for all the electrical shorts and found none. My fuel pump works fine. No clue to where to check next. Any info related to this problem is much appreciated.
Thanks
kevin_lu0471 is offline
post #6 of 7 Old 09-21-2007, 09:12 PM
Senior TN Member
Quoted: 12 Post(s)
Check the oxygen sensor wire harnes at the exhaust manifold and front exhaust pipe. NEVER EVER REPLACE A FUSE WITH A LARGER ONE NOT IN A CAR,TV,APPLIANCE OR ANYTHING ELSE.
Sidney® ™
Repairs TV's,VCR's,home/car audio out of my apartment
E-mail:sidneybek(at)yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,with 256 000 KM
http://web.archive.org/web/200403121...1019+Business+
http://web.archive.org/web/200402290...6.raw+Business
http://groups.google.com/group/hfx.f...4c696fbf04837f
http://www.iwaynet.net/~nesda/May02/May18.html
http://www.iwaynet.net/~nesda/SonyAudMod.html
http://www.repairfaq.org/sam/sonytune.htm#sonynoi
http://www.iwaynet.net/~nesda/Oct02/Oct028.html
http://www.iwaynet.net/~nesda/Oct02/Oct029.html
http://www.iwaynet.net/~nesda/Oct04/Oct041.html
for I am
Sidney is offline
post #7 of 7 Old 09-22-2007, 10:35 PM
Quoted: 0 Post(s)
Gen1
You're right Sidney. Thank you for your advice. It was the oxygen sensor wire close by the exhaust pipe. I found the heat shield under the driver seat cut thru the rubber jacket and grounded the black wire. I discovered this culprit last Wednesday and just got it fixed. My '88 4runner is running beautiful right now. Again, thank you very much.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
User Tag List
Linear Mode Linear Mode
« Back
