few problems with my 4runner - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
Old 11-20-2003, 02:33 PM   #1 (permalink)
View yota96's Photo Gallery
96 4Runner 63K
It talks to ya when its shut off......something under the hood is vibrating when the engine shuts off, its weird sounds like some sort of pressure built up somewhere, the noise is no where near the engine but the back right corner area under the hood. You guys got any ideas? Or anyone have this problem??
Also my rear brakes are covered in oil/grease, would it be from the differentials or something??
Thanks gregg
yota96 is offline   Reply With Quote
Old 11-20-2003, 02:49 PM   #2 (permalink)
Listen Fatboy....
JeremyH's Avatar
View JeremyH's Photo Gallery
Re: few problems with my 4runner
Thanks gregg
Sounds like bad axle seals......can you be more descriptive about where it is coming from?
Curiosity killed Schrodinger's cat.....or did it?
JeremyH is offline   Reply With Quote
Old 11-20-2003, 03:23 PM   #3 (permalink)
honestly cant really tell there is oil everywhere, I haven't cleaned it off yet. I just got a peak at it when my truck was up on the lift for an inspection.
Gregg
Old 11-20-2003, 11:12 PM   #4 (permalink)
Listen Fatboy....
JeremyH's Avatar
If I were you, I'd spray everything down with some simple green and then powerwash it............then watch it for a week or so and see if you can pinpoint where the leak is coming from. However, it sounds like a bad axle seal to me.
Old 11-21-2003, 12:33 PM   #5 (permalink)
robinhood150's Avatar
View robinhood150's Photo Gallery
I believe the 3rd gens have a TSB out for the charcoal canister for the buzzing noise. Search alldata.com for the TSB.
Also, 3rd gens are notorious for leaking rear axle seals. Check that out before the oil reaches the drum brakes, otherwise you won't stop well and you'll need new brakes.
'93 4Runner V6 Auto 4x4
Robinhood's Lair.
robinhood150 is offline   Reply With Quote
