Antifreeze Smell - Toyota Nation Forum : Toyota Car and Truck Forums
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
post #1 of 9 Old 01-08-2009, 09:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA Antifreeze Smell
Hello everyone. I have a little problem. When I turn on my heater on my 4runner I get a slight smell of antifreeze, I thought maybe the heater core was leaking. I checked the floor board carpet to see if it was wet from a leaking heater core, but it was dry. Does anyone have any idea what coul be causing this antifreeze smell? Could the heater core be starting to go out? Or do I have bigger problems?
Thank You all In Advance!!
-Leo
leo_manz is offline
post #2 of 9 Old 01-08-2009, 09:42 PM
Quoted: 2 Post(s)
The leak may be small enough that it does not drip or its dripping on top of something.
You'll need to explore a little.
toyomoho is offline
post #3 of 9 Old 01-09-2009, 04:29 PM
Senior TN Member
sb5walker's Avatar
Quoted: 0 Post(s)
I'll be watching this thread with interest because my 89 V6 pickup has been doing the same thing for at least three years. Also no visible signs of leak, just a smell, so I figure it must be a tiny leak. I'll be removing my dash in a couple weeks, so I may find something then.
sb5walker is offline
post #4 of 9 Old 01-09-2009, 05:02 PM
Dave's
Quoted: 26 Post(s)
I once replaced the heater hoses and then started noticing that smell. Couldn't find anything anywhere. Finally had the wife rev the engine as I watched. The new hoses had tiny little streams of coolant emitting from them. I took them back and they guy told his boss they had some more of that defective hose returned. Seems there were pinholes every few inches the whole length of the hose. Now, I don't think that's your problem but the point is it could be a very small leak which may only show up under pressure. Mine was gone almost the second it dropped to idle and was vaporizing so there was no evidence of the leak and probably would have been quite some time before I noticed a drop in coolant level. You might try revving the engine but a pressure check might be better. Good luck!
Dave's is offline
post #5 of 9 Old 01-10-2009, 08:07 AM
Quoted: 0 Post(s)
1. Make sure reservoir is not too full-----overflow will do that.
2. Head gasket on back side of covers ok??
sjohn26 is offline
post #6 of 9 Old 01-10-2009, 11:14 AM
Quoted: 0 Post(s)
4runner no heat and antifreeze smell
have a 98 v6 with no heat. checked hoses which all warm up fine, so have ruled out blocked hoses or malfunctioning valve. rang toyota and was advised it may be thermostat or clogged
heater core- both expensive. any ideas?
njmvac is offline
post #7 of 9 Old 01-10-2009, 07:23 PM
Dave's
Quoted: 26 Post(s)
You should be able to change the t-stat for well under $20.
Dave's is offline
post #8 of 9 Old 01-12-2009, 01:59 PM
Soylent Green sales
fourwd1's Avatar
Quoted: 271 Post(s)
Do a pressure check on the cooling system and you should easily be able to locate the leak.
_No THANKs necessary !
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline
post #9 of 9 Old 01-19-2009, 04:03 AM
LTD
all back a da bus & s**t
Quoted: 0 Post(s)
And substantially less work and cheaper than a head gasket
LTD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
User Tag List
Linear Mode Linear Mode
Back
