Re: Explain to me how 4x4 works in my 99 4runner
It sounds like you have a Limited, correct? If so, you also have the option of AWD as well, which would be what the button is for. The 4WD shifter is purely to lock the center diff (4WD).
4 high would be for 4WD situations, and the 4 low is the lower gear range set.
You are correct on the rear locker bit. A full, selectable locker. Now get out there and use it!
Compared to AWD, a 4WD system adds a transfer case for low range gearing and is a 50/50 power split to front and rear driveshafts. And as I mentioned, assuming you have the Limited, you also have AWD, which is the best of both worlds. That multi-mode system was not available on other models in '99.
2002 4Runner Sport
285/75/16 MT/R's | Sway-A-Way & Old Man Emu suspension lift | TJM T15 front bumper | Rock Ware rear bumper | Slee sliders | Dual ARB's | 4.88 gears | Mickey Thompson Classic II's
