what maintenace should i perform to a new used 90' 4runner? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > 4Runner Forum > 4Runner Lounge
4Runner Lounge General discussion area for all generations of the Toyota 4Runner.
Old 02-20-2004, 03:22 PM   #1 (permalink)
View madmaniac's Photo Gallery
can i go ahead and change all the fluids?
i heard if you change auto tranny fluid it can open seals and start to leak?
also would it be wise to change the timing belt now?
anything else?
madmaniac is offline   Reply With Quote
Old 02-21-2004, 06:36 PM   #2 (permalink)
View Dangerdog's Photo Gallery
Well I just bought two 1990 4Runners and am doing the same thing.
Absolutely change all the fluids - there's no chance of you causing anything but good by doing that.
While you're doing it I'd suggest you run an engine flush in the oil prior to the oil change.
Also, consider putting Lucas oil supplement or similar in the differentials and transfer case.
As far as the timing belt goes, try and find out from the previous owner how long ago it was done. If you can't find out I don't know of any way of checking it, maybe someone else on the forum does. If in doubt I'd change it, that's what I'm doing with mine. Sure would be nice to find out if there's a way to check it - I'll post a seperate thread and see if we can find out.
good luck!
Dave Hachey
Dundas, ON, Canada
2 - 1990 4Runners
1 - 1971 AMC Javelin
Dangerdog is offline   Reply With Quote
Old 02-22-2004, 10:53 AM   #3 (permalink)
Offical nut
redfox435cat's Avatar
View redfox435cat's Photo Gallery
You can try a toyota dealer. give them the vin number and if the belt was done at a shop it would be in their system. would even say if the water pump was done with it or not
4x4 v6 04 tacoma
Your Driving?Were we going?
redfox435cat is offline   Reply With Quote
