Can't fill gas tank? - Toyota Nation Forum : Toyota Car and Truck Forums
1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
post #1 of 4 Old 01-07-2006, 09:20 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
USA Can't fill gas tank?
I have a 2002 Tacoma 4 cyl 2wd manual transmission. Whenever I try to fill up the tank at the gas station the gas nozzle turns off immediately like the tank if full. I first tank maybe the gas nozzle at the pump was broken, but that wasn't the case. So I then took of the gas filler neck to see if there were any obstructions in the neck. Didn't find any obstructions so I thought maybe there if a clogged vent line, but couldn't find any. Any suggestions what be greatly appreciated. I have owned toyota trucks for the past 11 yrs and have never had this problem before.
Thanks in advance for any help,
John
kayakjohn is offline
post #2 of 4 Old 01-08-2006, 01:13 AM
This Space For Rent
humanoid's Avatar
Quoted: 557 Post(s)
Try the thread below, not sure if it will help you or not.
http://toyotanation.com/forum/t103554.html
humanoid is offline
post #3 of 4 Old 01-08-2006, 06:28 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks
post #4 of 4 Old 01-08-2006, 02:33 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Cool Problem Solved
There is a vacuum hose that goes to the air filter box to the obd closed sensor that goes to the cannister that was the problem. When I changed the air filter about a week ago I forget to hook that hose up and it some how got pinch between the top and bottom parts of the air filter box.
Thanks for all the help guys. It is just one of those stupid things I have done while change the air filter in the dark.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 1st Generation (1995.5–2004)
User Tag List
Linear Mode Linear Mode
« Back
