02 tacoma how 2 change fuel filter - Toyota Nation Forum : Toyota Car and Truck Forums
1st Generation (1995.5–2004) 1st generation Tacoma information and discussion.
post #1 of 7 Old 04-06-2008, 03:51 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
where is the filter located? how do I change it?
kbc123 is offline
post #2 of 7 Old 04-06-2008, 09:50 AM
Hmmm...
chipsndukes's Avatar
Quoted: 0 Post(s)
start with the engine that you have, 4 cyl is on the block under the intake manifold, 6 cyl don't know.
What engine?
chipsndukes is offline
post #3 of 7 Old 04-06-2008, 09:52 AM
Hmmm...
Quoted: 0 Post(s)
btw, some models (maybe all) have a "lifetime" fuel filter, supposedly don't need to change it. I did mine, why do you think you need to change yours?
CD
post #4 of 7 Old 04-06-2008, 11:18 AM
This Space For Rent
humanoid's Avatar
Quoted: 557 Post(s)
If you have the 6 cyl. it's bolted to the frame under the driver's seat. See the link below and scroll about half way down for the DIY on the 6 banger.
http://www.4x4wire.com/toyota/mainte...tenancep5.html
humanoid is offline
post #5 of 7 Old 04-07-2008, 01:03 AM
Senior TN Member
Quoted: 77 Post(s)
Irregardless of which motor you have (4 or 6), be sure to relieve the fuel pressure before removing the fuel filter.
Locate the fule pump relay fuse. Remove it. Start the vehicle. It will die shortly after starting with the fuel pump relay fuse removed. Do this again.
You'll get some fuel spillage when you pull the filter, but having relieved the system of pressure, you will not get a gasoline shower when you pull the filter.
2004 4 cyl. filter is on drivers side.
Mike Murrell is offline
post #6 of 7 Old 04-07-2008, 01:29 AM
Offical TN Hillbilly
TcmaBoy's Avatar
Quoted: 0 Post(s)
The V6 is a lifetime filter, do not change it unless you are ready to deal with stripped fuel fittings. They run an interference thread that prevents leaks over time. The threads strip as you tighten them, so they can't come loose. They have to be replaced with the filter. I found this out the hard way and I now have a GM filter on the truck because I could not find the metric fittings.
Don't you SAS me boy.
Please wheel responsibly.
TcmaBoy is offline
post #7 of 7 Old 04-07-2008, 06:08 PM
'Coma Nut
ForTech's Avatar
Quoted: 1 Post(s)
Weird. When I owned my 98 I changed the fuel filter three times without problems. Didn't even use the proper line wrench, just a normal everyday open end wrench.
2005 Tacoma TRD Off Road 4x4 Access Cab
ForTech is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Tacoma Forum > 1st Generation (1995.5–2004)
User Tag List
Linear Mode Linear Mode
« Back
